1995 Tacoma Rear Shock Advice (With Pics)
Discussion in '1st Gen. Tacomas (1995-2004)' started by MAUIAUSTIN, Jun 10, 2024.
  1. Sep 5, 2024 at 1:52 AM
    MAUIAUSTIN
    MAUIAUSTIN [OP] Well-Known Member
    Austin
    Maui, Hawaii
    1995 Ext. Cab 4x4 SR5
    Sway A Way 2.5 Coilovers JBA Upper Control Arms Old Man Emu CS019R Leaf Springs Old Man Emu Stock Length Greasable Shackles 10" Travel Bilstein 5125 17" DX4 Terrain Wheels 265/70 R17 Falken Wildpeak AT3
    Had to edit the post so that i dont forever look like a fool.
    EDIT: I later realize i didnt math this right but the problem was still real lol
    Diablo169[QUOTED] likes this.
  2. Sep 5, 2024 at 6:57 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Not sure if you ever saw this thread I put together, but I have all the part numbers listed for all the Bilstein 5125 shocks: https://www.tacomaworld.com/threads/1st-gen-tacoma-rear-shock-info-aftermarket.793217/
    I also prototyped a bolt on outboard shock relocation: https://www.tacomaworld.com/threads/feeler-1st-gen-tacoma-bolt-on-outboard-shock-mounts.794657/
    These require wheel spacers, but they do move the shock mount 3" higher. I have the parts to make one more set if you were interested.
    MAUIAUSTIN[OP] likes this.
  3. Sep 5, 2024 at 7:28 AM
    Tacodrew22
    Tacodrew22 Well-Known Member
    Andrew
    Michigan
    2022 Tacoma TRD Off-Road
    OnX Off-Road Trail Guide. I help OnX map and document routes. I get out all across the United States but based in Michigan
    You may be able to add some taller bump stops to avoid over compressing the shock
  4. Sep 5, 2024 at 9:38 PM
    MAUIAUSTIN
    Austin
    Maui, Hawaii
    This is super cool actually. I have no fabricating experience so a kit like that makes for a great option for relocating the shocks without having to weld or modify the frame or mounting points! Great work on making that kit, id need to give it a bit of thought if i want to get one from you due to the fact I just completed the lift kit and shocks dont sell too well on the second hand market. Weve got a surplus of second hand shocks and facebook people live to lowball lol
    nzbrock[QUOTED] likes this.
  5. Sep 5, 2024 at 9:39 PM
    MAUIAUSTIN
    Austin
    Maui, Hawaii
    This is my plan when i eventually find out how much longer theyll need to be!
    Tacodrew22[QUOTED] likes this.
  6. Sep 12, 2024 at 11:22 PM
    AW11
    AW11 Well-Known Member
    Frank
    2002 Dbl Cab 4x4 3.4l
    Do you have the link for the energy suspension bushings?
