1995 Toyota Tacoma V6 Single Cab-Phoenix AZ
Discussion in '1st Gen Tacomas For Sale (1995-2004)' started by jacobrippey, Jun 5, 2021.
  1. Jun 5, 2021 at 6:22 PM
    jacobrippey
    jacobrippey [OP] It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Phoenix, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    For sale is my 1995.5 Toyota Tacoma called Jethro. It's a V6 Single cab 4WD with an E-locker...a true unicorn...er...horse with a horn tied to its head. More on that later.
    -Do you like driving something that never gets lost in a parking lot?
    -Do you enjoy living in the outdoors?
    -Do you want a Jeep, but with a bed and actual reliability?
    -Are small cars seen as speedbumps?
    -Are you a fan of Radwood colors?
    Then I've got the truck for you!
    -Legendary 5VZFE 3.4 V6 engine (please read below)
    -5 Speed manual (because #savethemanuals)
    -Manual hubs (nothing to break offroad, except the smug looks of a Jeep owner's face.)
    -Armored for all that the mall parking lots can throw at you!
    -Steel wheels, because no frills
    -Locking diff
    This truck has been a solid companion of mine for over 7 years now, but I wanted a bit more room, and ended up going with a 4 door Tacoma. Truck has made several trips to and from Colorado and even a trip to Moab.
    This truck has been built and modified to be an excellent off-road adventure and camping vehicle.
    Some Notes:
    -Truck has been V6 swapped around 20k miles ago. Engine, Trans, and Transfercase were all lower mileage. Engine was resealed from the headgaskets up. All factory emissions equipment carried over and the truck has passed emissions in Colorado and Arizona, as the engine was from a 1996. Truck averages 17-18 mpg since the swap.
    -There is no rust! Those who know about early Tacoma's should look for this.
    -AC blows ice cold, Heater will roast you.
    -Truck has a salvage title due to hail in 2010. The entire driver's side has hail dents. The carfax says that the truck was totaled due to "non-collision damage". Truck also has some hail dents on the hood from Colorado (if you know, you know about the summer weather out there).
    Modifications:
    Powertrain-
    -V6 Swapped
    -4.30 gears and E locker out of a 1999 4runner
    -Rear axle housing from 2004 Tacoma
    -Deckplate Mod
    -Airaid Intake Piping
    -Rear Diff breather
    -Tundra Brakes (199mm) w/ Stainless lines
    Wheels/Tires-
    -17" Steelies from FJ Cruiser
    -255/75/17 KM1's from JK Rubicon (around 1/2 tread)
    Exterior-
    -Relentless FAB front bumper
    -CBI Bushmaster 1.0 Rear Swing Out
    -Trail Gear Sliders
    -Sky E-Locker Skid Plate
    -Hella (looking) horns
    -Canback soft topper (this is the best soft topper you can buy as you can mount tent on top)
    -Ski rack (a bit ghetto, but very useful. I had awnings mounted to it once-upon-a-time.)
    -Hilux Snorkel
    -Cam Can
    -4runner power mirrors (bigger than stock, unwired but comes with harness)
    Suspension-
    -Old Man Emu full kit (2881 springs, nitrochargers, Dakar Springs)
    -SPC upper control arms
    -Poly rack bushings
    -Poly swaybar bushings
    -CBI Frame plates (to help with weight of rear swing-out)
    Lighting-
    -LED headlights from an XJ Cherokee (night and day difference from sealed beams)
    -LED in bed (un-wired)
    -PIAA fog lights (un-wired)
    Interior-
    -2001 Bucket Seats
    -2001 Door Cards
    -Paracord door handles
    -Pioneer speakers
    -LED dome light
    I have a huge pile of spares and extra parts to go with the truck.
    Recent Maintenance:
    ***all oil changes done with synthetic oil and OEM Toyota Filters
    233,700 V6 Swap (engine had 169k). Resealed motor, new belts, new hoses, new clutch, fuel filter, etc.
    236,853 Oil, Filter
    242,079 Oil, Filter
    245,489 New OEM lower ball joints, new tie rods
    246,666 OEM spark plugs
    248,692 Oil, Filter
    250,202 Coolant flush, new OEM t-stat, new hoses
    250,230 New front brakes (whole system), replaced most vacuum lines
    250,270 New PCV valve
    250,371 New front and rear diff oil, new OEM bolt. Drivers side front diff seal replaced.
    250,938 upgraded aluminum radiator, new hoses, new coolant.
    251,439 new cat converter
    251,971 New lower control arm bushings, sway bar bushings and links, transfercase front driveshaft seal
    251,980 alignment
    252,991 new fan clutch (oem), cleaned radiator, new coolant
    253,215 oil, filter
    253,603 tire rotation, alignment
    253,993 New steering rack, Tie Rods, alignment
    Keeping in mind that this is now considered a classic vehicle by the State of Arizona, there are a few issues that one might address:
    -The differentials have small leaks.
    -Fuel gauge shows 1/4 tank lower than actual
    -Passenger CV axle boots are torn. I have an OEM Toyota re-boot kit for it.
    -E Locker is temperamental. May need a new locker motor.
    -E brake is weak. Needs the correct cable for the newer rear axle
    -Canback is torn in a couple of places.
    -There is an exhaust leak somewhere. I have yet to find it.
    Overall, this truck has been a friend of mine for the last 7 years. I have had many adventures and memories in this truck, and am hoping the next owner finds the same joy. I am looking for 9200 obo. Vin and 24 pg build thread (https://www.tacomaworld.com/threads/jacobrippeys-1995-v6-swapped-tacoma-single-cab-build.464821/) can be provided upon request. Truck also comes with records going back to the 90’s and even the original window sticker. I am not interested in trades, payments, or checks. Cash only.
    IMG_0477a.jpg IMG_0478a.jpg IMG_0483.jpg IMG_0490a.jpg IMG_0491a.jpg IMG_0492.jpg IMG_0493.jpg IMG_0496.jpg IMG_0503a.jpg
    rtwbound, TWENTYCO, League4 and 2 others like this.
  2. Jun 5, 2021 at 7:04 PM
    digitalferg
    digitalferg Well-Known Member
    Southern Utah
    2006 1G Tundra DC TRD 4x4
    Bitchin single cab! I bet this won't last long.
  3. Jun 6, 2021 at 3:12 AM
    TheBraves
    TheBraves Active Member
    West Virginia
    1999 Toyota Tacoma Reg Cab 4x4
    2.5 Rough Country strut lift. All new springs. 33/12.5/15 Mickey Thompson MTZ. 15x8 wheels.
    If you only lived closer!
    OG_Tacoma likes this.
  4. Jun 6, 2021 at 3:23 AM
    HasbroGamer
    HasbroGamer Well-Known Member
    Nicola
    Washington State or Arizona
    2007 V6 Tacoma TRD Sport Double Cab
    Bed Stiffeners, Martin roof rack, 2 inch Dobinsons lift, black seat covers, taco garage tech deck and ram mounts, amazon backup camera, custom 2.5 gen facelift, Stingray front bumper, Diode dynamic foglights, wheels & tires, OME leafs.
  5. Jun 6, 2021 at 3:25 AM
    charliehex
    charliehex I belong in the dirt.
    Charlie
    Phoenix, AZ
    2021 Barcelona Red TRD OR DCSB
    285/70/17C BFG All Terrain TA KO2 Method 701 - Bronze 3”F/1"R Spacer Lift Sprint Booster MESO: Gasshole, Map Lights, Sequential Turn Signals Rough Country: Speedometer Calibrator, F/R Seat Covers R4T: Tail Gate Remote Rago: Center Console Molle Panel sPOD: Switch Controller Lamin-x: Amber Fog Light Covers ARB: Twin Compressor Slee Off Road: ARB Twin Compressor Mount Expedition Essentials: 3TPAM Accessory Mount RAM Mounts: Short, Long, Long arm, GoPro Mount
    It’s at the bottom of the post. $9200
    OG_Tacoma and jacobrippey[OP] like this.
  6. Jun 6, 2021 at 3:34 AM
    HasbroGamer
    Nicola
    sorry I'm blind I guess
  7. Jun 6, 2021 at 3:41 PM
    easleycrawler
    easleycrawler Well-Known Member
    Travis
    Easley, South Carolina
    2014 RC Taco 4wd
    If I could sell my rock crawler, I'd be buying a plane ticket, flying out and drive this back to the east coast.
  8. Jun 6, 2021 at 3:49 PM
    BartMaster1234
    BartMaster1234 American Auto Horns
    Tyler
    San Francisco, California
    Flux Capacitor
    Sick. The canopy looks fantastic.
    jacobrippey[OP] likes this.
  9. Jun 7, 2021 at 12:12 PM
    Nick1999
    Nick1999 Well-Known Member
    Arizona
    2004 Red Tacoma S Runner
    No
    Why did you swapped the engine?
  10. Jun 7, 2021 at 12:27 PM
    tortoise_taco
    tortoise_taco Well-Known Member
    battle born
    1996 2.7L 4x4 / 2013 SR5 V6 4x4
    the good ones
    One of the coolest trucks I've seen listed here. Good luck with the sale and congrats to the new owner!
  11. Jun 7, 2021 at 12:30 PM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Well, when living in Denver, the 4 cyl 3RZ didn't have any cajones. I found a deal on a parts truck with a bad frame. What was cool is that the truck also had features mine didn't, which swapped over also (clock, tilt column, tach, etc.)
  12. Jun 7, 2021 at 12:51 PM
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
    I was just reading your build thread a few days ago. I left off where you got it running post swap. It’ll go quick, I’m sure.
  13. Jun 7, 2021 at 1:26 PM
    bmwahba
    bmwahba Well-Known Member
    Wow, I am considering shipping this thing to Florida!
  14. Jun 7, 2021 at 1:32 PM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    I get a lot of questions about the Canback at car shows. It’s a shame that they don’t make them any more.
  15. Jun 7, 2021 at 1:33 PM
    Nick1999
    Arizona
    No
    Understand. 100% agree with you.
  16. Jun 7, 2021 at 1:37 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Son of a bitch I love that truck. I’m surprised it isn’t snatched up yet
  17. Jun 7, 2021 at 1:39 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    This thing is rad. looks like it's been well taken care of. Someday I want to sell my 2nd gen for a nicer daily and buy a dedicated trail rig like this. Good luck with sale OP!
  18. Jun 7, 2021 at 1:45 PM
    Nick1999
    Arizona
    No
    • Good for you! I'm sure you'll have no regrets. This is a great example, and the price is very good for you!
  19. Jun 7, 2021 at 2:24 PM
    OG_Tacoma
    OG_Tacoma Well-Known Member
    10/10 excellent post. Even better truck!
    GLWS and following to see who the lucky winner is.
  20. Jun 7, 2021 at 10:20 PM
    Nick1999
    Arizona
    No
    This is the best looking first gen Tacoma TRD I've seen in TW!
    jacobrippey[OP] and Empty_Lord like this.
