1995 v6 4x4 alternator question
Discussion in '1st Gen. Tacomas (1995-2004)' started by guinness, Jun 7, 2016.
  1. Jun 16, 2016 at 8:44 PM
    guinness
    guinness [OP] Member
    Ive been looking everywhere for a pinched wire but cant find anything. Im going try and dig deeper into it this weekend when I actually have some time.....
  2. Jun 19, 2016 at 3:40 PM
    guinness
    So still trying to pin point what the hell is causing all my problems, I started checking how much amperes are being drawn with the engine off and the ignition turned on. I'll get either 2.77A or -1.69A so I know theres gotta be a faulty wire. thing that is really confusing me is that after after pulling fuses and re testing I'm still getting a reading of 2.77A. Shouldn't removing the fuse that the faulty wire is on drop my amperes down to a normal reading?
  3. Jun 30, 2016 at 7:47 AM
    NvrSyNvr
    NvrSyNvr Well-Known Member
    Jim
    2000 Green PreRunner Xcab V6 Auto w/locking diff
    Hayden 678 Transmission Cooler
  4. Jun 30, 2016 at 10:08 AM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    keep in mind the first half is untrue for our trucks though. mainly because our computers, radios, and some with alarms are constantly drawing power from the battery. and use caution while youre at it. leaving just the negative connected runs the risk of static shock running through and potentially frying a small chip. so keep that test light between the positive and its cable.
  5. Jul 2, 2016 at 12:58 PM
    guinness
    still have not figured it out... When i used a test light the fuse that'd make it not light up is the 15a dome in the engine compartment.
  6. Jul 4, 2016 at 2:48 PM
    ashleyroachclip
    ashleyroachclip Well-Known Member
    I have had internally regulated alternators , draw current with the key and engine off.
    I did not recall if you have replaced the alternator.
    I will reread your thread .
  7. Jul 4, 2016 at 2:53 PM
    ashleyroachclip
    So after a quick scan of your first post.
    Does your truck have a reciever with a round plug for trailer lights?
    In that plug is a lead , 12 volts, to charge a battery in like a camp trailer etc .....
    Unplug the trailer harness , see if you dont have 14.5 volts at an idle , and if your problems go away.
    I am thinking that harness has been pinched to ground .
