1996 2-Door SX - Good Base For Dedicated Crawler?
Discussion in '1st Gen. Tacomas (1995-2004)' started by gunn_runner, Apr 3, 2017.
  1. Apr 12, 2017 at 4:00 PM
    #41
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    the problem with the ECU swap is there are two 97ecus. One goes till May the other is post May. Only the Post May ones work far as i know. VERY hard to find. No harness swap is needed though far as i know.
    also didn't solve my ECU problems swapping one over.
    1997tacomav6 likes this.
  2. Apr 12, 2017 at 5:09 PM
    #42
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    I don't think you could pay me to put another Toyota-based crawl box in a truck of mine.
    With that being said, my Atlas 4 leaks more than it ever should for only having 500 road miles on it, but at least I know I will never break it :D
    nDub likes this.
  3. Apr 12, 2017 at 5:15 PM
    #43
    1997tacomav6
    Denver
    I'm pretty sure these are the knock sensors I bought for 85.00 for the set new sealed
    http://www.ebay.com/itm/GENUINE-OEM...NOCK-SENSOR-/182069052653?hash=item2a642944ed
    #43
  4. Apr 12, 2017 at 5:35 PM
    #44
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Leaking = ubreakable?
  5. Apr 12, 2017 at 5:59 PM
    #45
    allenfab
    Todd
    Lakeland, FL
    It's either a stout case that leaks, or a weaker Toyota case that leaks :rofl:
    DustStorm4x4[QUOTED] likes this.
  6. Apr 12, 2017 at 7:12 PM
    #46
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I like how customizable they are...
    Passenger drop FTMFW
    If you want to run a toyota 8" front end that is.
  7. Apr 12, 2017 at 7:38 PM
    #47
    butsack
    butsack Well-Known Member
    SW WA
    1997 Reg cab 3rz auto
    aftermarket cassette player
    how do i find out which ecu is in my 97?
  8. Apr 12, 2017 at 7:39 PM
    #48
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    It looks like you have a 4cyl. The v6 one is a different ecu.
  9. Apr 12, 2017 at 7:50 PM
    #49
    1997tacomav6
    Denver
    Is that gas mileage correct shown below for your four-cylinder? if it is the six cylinder is going to be about the same gas mileage, my v6 supercharged is almost the same as your four-cylinder
  10. Apr 12, 2017 at 8:25 PM
    #50
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Actually the mpg shows higher than it is. My speedometer reads 10mph faster after I regeared.
    1997tacomav6[QUOTED] likes this.
  11. Apr 12, 2017 at 9:35 PM
    #51
    butsack
    SW WA
    my bad :D
    ...also is gas mileage important to ppl building dedicated crawlers??:confused:
  12. Apr 12, 2017 at 9:43 PM
    #52
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Meh. Mine is 90% daily driver. 10% off-roader. Mpg is important-ish.
  13. Apr 13, 2017 at 3:35 AM
    #53
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    I have an atlas :D It is the 2spd though.
    The toyota-based transfer case stuff ends up being as expensive as a 4spd Atlas after everything is said and done. Not worth it.
    I'll take the former any day :D
    nDub[QUOTED] likes this.
