1996 3.4l m 4x4 extra cab taco restoration
Discussion in '1st Gen. Tacomas (1995-2004)' started by Noob95.5, Oct 5, 2019.
  1. Feb 6, 2020 at 5:07 PM
    #101
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Id say its just a Taco issue in general. Ive driven 3 Toyota trucks with manual trannys. Every one of them did this. I dont worry about it. :notsure:
  2. Feb 6, 2020 at 5:08 PM
    #102
    Noob95.5
    Noob95.5 [OP] Well-Known Member
    96 xtra cab 3.4l 4x4 manual
    just making sure
    GQ7227 likes this.
  3. Feb 6, 2020 at 5:11 PM
    #103
    Noob95.5
    A few more
    Before and afters
    GQ7227, Babybluetaco and ontarioyota like this.
  4. Feb 7, 2020 at 6:38 PM
    #104
    Noob95.5
    Anyone dealing with a squeaky clutch pedal? Driving me nuts.
    Also any fixes for a seatbelt that doesn’t automatically respool?
    GQ7227 and Running Board Man like this.
  5. Feb 7, 2020 at 6:56 PM
    #105
    Running Board Man
    Running Board Man Well-Known Member
    My buddys t4r has a squeek in the column and clutch pedal
    Noob95.5[QUOTED][OP] likes this.
  6. Feb 7, 2020 at 6:57 PM
    #106
    Noob95.5
    Any thoughts on cause/solution? Obvious methods aren’t working
  7. Feb 7, 2020 at 7:02 PM
    #107
    Running Board Man
    No... not my truck and he doesnt care about it
  8. Feb 7, 2020 at 8:40 PM
    #108
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    double clutch down shift for the win! Don’t think I’ve owned a manual that was easy to shift down into 1st without a double clutch down shift.
    my clutch on my ‘04 starts squeaking about every 8 months or so. Pb blaster or wd40 (whatever I have handy at the time) up in the spring does the trick. It’s probably originally greased, but I’m not about to try to grease it.
  9. Feb 7, 2020 at 8:45 PM
    #109
    GQ7227
    GQ7227 mw survivor
    J A Y
    yes
    yes ... maybe ... waiting on @jammer
  10. Feb 7, 2020 at 8:48 PM
    #110
    GQ7227
    GQ7227 mw survivor
    J A Y
    there is a linear spring mod that some have done with good results
    i have Nut-Z lube on mine currently for close to 2 months no squeak
    its not just for tight nuts!
  11. Feb 8, 2020 at 4:44 AM
    #111
    Noob95.5
  12. Feb 8, 2020 at 4:44 AM
    #112
    Noob95.5
    Elaborate please
  13. Feb 8, 2020 at 5:16 AM
    #113
    GQ7227
    GQ7227 mw survivor
    J A Y
    Noob95.5[OP] likes this.
  14. Feb 8, 2020 at 6:01 AM
    #114
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    GQ7227 likes this.
  15. Feb 8, 2020 at 6:04 AM
    #115
    chainslap
    chainslap Well-Known Member
    Prescott, AZ
    95.5 SR5 V6 5spd 4x4, 2020 Tundra TRD DC
    Replace the clutch bushing, spring, and pedal. Your bushing is gone I bet and both the spring and pedal are probably grooved. I've done at least three bushings in my truck (308k) and a couple pedal assemblies. The design kind of sucks but the advantage of that spring is it helps push the pedal to the floor about midway and vice versa. Replacing it with a linear spring sucks as you are constantly fighting a spring at that point. Your leg will get tired fast if you drive in any kind of traffic, unless it's a real light spring.
  16. Feb 8, 2020 at 6:45 AM
    #116
    ToyotaDriver
    Idaho
    Regardless of whether it’s synchronized or not, matching the speed of the input to the gear you’re trying to get into will make it easier. Assuming your trans is a r150f since it’s a v6. My r150f is difficult to shift into first without rev matching even though it’s synchronized. When I took my trans apart to replace the input shaft, I cleaned everything and that made it a little easier to shift into 1st, but didn’t get rid of it entirely. Other ones I’ve driven are the same way as are transmissions in a lot of other pickup makes. I think it’s just the nature of the beast, unless I’m misunderstanding your issue.
  17. Feb 8, 2020 at 6:47 AM
    #117
    ToyotaDriver
    Idaho
    Admire the work you’ve done so far. Keep it up!
    jammer and Noob95.5[OP] like this.
  18. Feb 8, 2020 at 6:51 AM
    #118
    GQ7227
    GQ7227 mw survivor
    J A Y
    +2
  19. Feb 8, 2020 at 5:44 PM
    #119
    GQ7227
    GQ7227 mw survivor
    J A Y
    1st negative remarks i've seen regarding the linear spring mod
  20. Feb 9, 2020 at 8:07 AM
    #120
    chainslap
    Prescott, AZ
    JMHO. Your results may vary.
