1996 Integra GSR Sedan
Discussion in 'Other Builds' started by danteisme, Aug 18, 2016.
  1. Mar 12, 2018 at 8:09 AM
    #141
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    yup, i have a few saved on ebay for when i go to replace them. its a stupid setup in my opinion. Here, pry out these pieces of plastic that are in the dashboard via pressure clips, but be careful not to break them.
  2. Mar 12, 2018 at 9:21 AM
    #142
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    ouch rough weekend. are you thinking about taking it to a body shop to fix the windshield area or try to tackle it yourself?
    i need to fix my hood. for some reason the rear of it sticks up above the fenders almost like there are spacers but there arent.
    the clips that get me are the little metal ones on the plastic tabs for the interior panels. pull the panel and the metal clip breaks the plastic half the time
  3. Mar 12, 2018 at 10:17 AM
    #143
    danteisme
    South Western PA
    I'm gonna try real hard not to take it to a body shop just because if i need to do that the car will be off the road this year. It's going to take a while to save up for that repair. i'm going to do some exploring in that area this weekend and see how bad it is and how far it goes.
  4. Mar 12, 2018 at 10:32 AM
    #144
    Sacrifice
    KS
    DCSB OR 4X4 LT
    i understand that, hope the best since youve been putting tons of work in :fingerscrossed:
  5. Mar 12, 2018 at 10:38 AM
    #145
    danteisme
    South Western PA
    Got another positive thing going, a friend on honda-tech has an extra climate control unit laying around and he said he'll send it to me. So that's one fubar i can cross off my list lol
    Sacrifice likes this.
  6. Mar 19, 2018 at 10:01 AM
    #146
    danteisme
    South Western PA
    So, I think I lucked out. I did my investigating and within maybe 15 seconds or so of grinding at the rust, i found clean metal. I did find two very small perforations but they can be easily tacked shut.
    However, right above the clean metal I found more traces of rust going up under the windshield.
    So, the situation escalated quickly from there...
    So, after fighting with the windshield for freakin 5 hours, its out. That 22 year old glue and sealant did not want to let go. And, I probably should have asked someone to come over and help me take it off. I made that harder than it needed to be doing it myself. I found 2 more small sections of rust. Again, i spent some time with a wire wheel and got down to clean metal again. So, I think I lucked out. I'll finish cleaning it up and spray some rust inhibiting paint on there before I prime and paint. THEN, i'll finally get the glass company to come out and do there work.
    So, I'm frustrated that I found this but at the same time I'm glad I found it. I'm frustrated because its going to add a good bit of time onto my schedule for getting the car back on the road, but I'm glad because I caught it while it is fixable and I'll have some piece of mind knowing that I took care of it correctly.
    BadBrains likes this.
  7. Mar 19, 2018 at 10:41 AM
    #147
    Sacrifice
    KS
    DCSB OR 4X4 LT
    doing work. whatd you cut out the windshield with?
  8. Mar 19, 2018 at 11:28 AM
    #148
    danteisme
    South Western PA
    i used a cheap windshield removal tool i got off Amazon or ebay, but i swapped out the cheapo piano wire they give you with some braided cutting wire. it worked great when i used it to remove that rear windshield at the upull yard, but on my car it took FOREVER to cut through the glue and sealant on the front windshield. FOREVER lol
  9. Mar 26, 2018 at 7:30 AM
    #149
    danteisme
    South Western PA
    All down to good metal and first step applied! Rust converting / inhibiting primer. Next step will be scuff that up slightly and applying chassis saver.
    BadBrains and Sacrifice like this.
  10. Mar 27, 2018 at 1:12 PM
    #150
    Sacrifice
    KS
    DCSB OR 4X4 LT
  11. Mar 28, 2018 at 5:57 AM
    #151
    danteisme
    South Western PA
    oooooooooooooooooh why hello there!
  12. Mar 28, 2018 at 6:04 AM
    #152
    Sacrifice
    KS
    DCSB OR 4X4 LT
    dont see many DB front end conversions. looks pretty good imo
  13. Mar 28, 2018 at 10:20 AM
    #153
    danteisme
    South Western PA
    I do like them, i was >< this close to pulling the trigger on doing that mod when i decided just to stick with the classic 94-97 front end. You would think that i would have gone with the jdm front especially after i cut out the core support on the car to make that repair lol
  14. Mar 28, 2018 at 10:58 AM
    #154
    Sacrifice
    KS
    DCSB OR 4X4 LT
    its not too late :cookiemonster:
    danteisme[QUOTED][OP] likes this.
  15. Apr 9, 2018 at 10:21 AM
    #155
    danteisme
    South Western PA
    Finally got around to coating the area, just need to add some green paint and get the window guys out here.
    I tried using the stronger goof off stuff to remove the glue adhesive off my door panels, it removed some but it made them super sticky. what else could i use to safely remove this from the door panels?
  16. Apr 9, 2018 at 1:03 PM
    #156
    Sacrifice
    KS
    DCSB OR 4X4 LT
    no ideas from me :notsure: ive never messed with fabric glue
  17. Apr 9, 2018 at 10:45 PM
    #157
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    I don't know, maybe tape it off and use some mineral spirits or acetone. In the Navy we used MEK (Methyl Ethyl Ketone) until it was banned, then it was Naphtha, ie Aliphatic Naphtha for adhesives. It's almost identical to Zippo fluid, I used to fill my Zippo with it.
  18. Apr 10, 2018 at 4:31 AM
    #158
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    I've always had luck with Goo-Gone brand. Not sure how it compares to the heavier duty Goof Off you already used.
  19. Apr 10, 2018 at 8:58 AM
    #159
    danteisme
    South Western PA
    I havent had this much trouble removing the adhesive before, i also didnt use heavy duty headliner adhesive before either. Apparently that makes a big difference. i'll have to try some acetone next and see if i can remove the glue and not the door panel plastic lol
  20. Apr 19, 2018 at 10:59 AM
    #160
    danteisme
    South Western PA
    Alright, i have a few updates. i went to the local upull yard and snagged an undamaged climate control system for the car since i broke mine. 30% for the day, so i believe i paid $18 for it? I also grabbed just about every fender liner clip and side skirt clip i could find.
    Then that night i finished up the paint work for around the front windshield.
    Then Sunday all hell broke loose. I have never, EVER been so sick in my life. I am still not 100%, hell i'm not even 50%. I got the flu so freakin bad it sent me to the ER Monday night, which I am very glad my wife forced me into that. Despite being sick, Wednesday morning the glass company came out and installed that rear glass i pulled from the yard a while back, and installed a new front glass with new window trim. i still need to install the side trim pieces, but it will be nice having clear glass finally.
    Now i can start really putting this car back together. Maybe not this weekend though, i still feel like i need to sleep for about a year...
