1996 po172
Discussion in '1st Gen. Tacomas (1995-2004)' started by Milton10, Jan 5, 2025.
  1. Jan 5, 2025 at 12:28 PM
    Milton10
    Milton10 [OP] New Member
    When letting off the clutch in 1st gear or reverse the truck would almost choke out unless you were heavy on the gas. (Replaced Maf air filter and 02 sensors) runs better but still does it regularly and still says running rich. Any idea of what it could be?
  2. Jan 5, 2025 at 3:24 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Looks like u covered some likely causes
    With O2’s
    MAF filter? Did you clean MAF?
  3. Jan 6, 2025 at 8:34 AM
    Milton10
    I cleaned the throttle body. Replaced the maf and the regular air filter. Still has a little rough idle and acts like it’s stalling when going into 1st
  4. Jan 6, 2025 at 2:41 PM
    ControlCar
    Steven
    Sugar Land TX
    b4 sending injectors to MotorWest for remanufacturing
    i would rule out intake leak with chorinated brake cleaner test
    have engine running and spray the brake cleaner around all intake hoses(small and large) and also injector cups(under the injectors if 2rz/3rz(plastic could be cracked letting in un-metered air)
    if engine surges.....there is your leak
