1996 Rear Drive Shaft Vibrations
Discussion in '1st Gen. Tacomas (1995-2004)' started by lupy1234, Jun 29, 2012.
  1. Jun 29, 2012 at 3:43 PM
    lupy1234
    lupy1234 [OP] Member
    Hi...I have a 96 Tacoma 4x4 (2.7L) and the center bearing in the cardon joint failed. Toyota wants $1900 total to replace. Yep. Nough Said on that. Pulled the drive shaft off and running in 4WD until I find a replacement...only used to go and back to work. Does anyone know where I can find a replacement drive shaft? Or, I have heard that a 4Runner drive shaft (do not know the year) can replace it but it does not have the double cardon joint. Is this true? Any help will be greatly appreciated.
  2. Jun 29, 2012 at 3:48 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    driveshafts are not easy to come by ill pm you information about a guy i got mine from. and i do not know about a 4runner shaft would be nice to know though cause i know where one is.
