1996 tacoma 3.4--What year engines will fit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bigbucks, Feb 10, 2012.
  1. Feb 10, 2012 at 8:19 PM
    bigbucks
    bigbucks [OP] New Member
    Hello to all. I have been driving Toyota trucks for over 11 years now, and I have run a body shop for 19 years so I have some experience in the field. I recently purchased a 96 Tacoma 4X4 ext cab with the 3.4L. Like so many others it had bad head gaskets, and I think the previous owner let it get hot (probably many times), and probably cracked the heads. When I bought it there was water in the oil and it was chuggin' tons of white smoke. But the price was right so I limped it home. Well she locked up in my driveway so instead of rebuilding the heads I am just going to try to find a used engine. I know that the 3.4s are the same from 95 to 99, but the block is the same up to 04. My question is, what is the difference in the 2000 to 2004 engines? Are the heads completely different or is it just the electronics and maybe intake?
    Thank you in advance for any answers!
    Kevin
  2. Feb 10, 2012 at 8:37 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    i heard of a guy putting an LS1 in his truck, but idk about the engine differences.
  3. Feb 10, 2012 at 8:46 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    I don't think anyone's done it on a 4x4 before.
  4. Feb 10, 2012 at 9:42 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Actually, head gasket issues on the 3.4L are very uncommon. Its predecessor however, the 3.0L, is a different story.
    The 3.4L was basically unchanged from the '96s thru the '04s.
  5. Feb 11, 2012 at 5:14 AM
    bigbucks
    Thanks for the replies.
    I am not looking to do an engine swap with anything other than another 3.4. But apparantly something is different in the 2000-04's. I know the blocks are the same but I was hoping the heads are as well.
    Thanks!
  6. Feb 11, 2012 at 6:53 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Everything is the essentially the same except the ignition/spark system I believe. You can get a 3.4L from 96-04 and it'll be good.
  7. Feb 11, 2012 at 11:56 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    This, all the 3.4l are the same except for EGR was on some and not on others.
    Nothing major tho.
    Swaping a new used one it will be easy.
  8. Feb 15, 2012 at 7:58 PM
    bigbucks
    Thanks so much for the replies! I hope you guys know what your talking about because I am about to purchase a 2004 engine tomorrow.
  9. Sep 28, 2016 at 2:09 PM
    Nealy123
    Nealy123 New Member
    Did the 2004 motor swap over fine???
  10. Dec 22, 2016 at 6:30 PM
    kmcmahon5
    kmcmahon5 Well-Known Member
    B.C.
    1996 Tacoma, 1989 pickup
    Older thread, but Im also curious on whats different. Putting a 04 motor in my 96 on a few weeks
  11. Dec 22, 2016 at 6:31 PM
    DustStorm4x4
    DustStorm4x4 Keep fighting for Net Neutrality
    Tristian
    TN
    '01 3.4L 4WD 5spd TRD
    fucktard with a spacer lift.
  12. Dec 22, 2016 at 6:32 PM
    kmcmahon5
    B.C.
    I guess I should have actually read all the replies lol. Thanks man!
    DustStorm4x4 likes this.
  13. Dec 22, 2016 at 6:35 PM
    DustStorm4x4
    Tristian
    TN
    lol it's all good.
  14. Dec 22, 2016 at 6:37 PM
    chaosrob
    chaosrob Well-Known Member
    the engines are the same but many accessories are very different. The idle up for P/S is vacuum in 96, the tps conection is different, etc. I would just use the block and intake but switch all the accessories over from your 96 to make life easy on yourself.
  15. Dec 22, 2016 at 6:42 PM
    chaosrob
    here is a 99 v 96 tb with tps from a 3.4
    99
  16. Dec 22, 2016 at 6:44 PM
    chaosrob
    If you have an early one the evap system could be completely different as well with a round can instead of the multi ported box with map sensor. Pay special attention to all the routing as the vac system is going to be completely different between the two, including some of the hard lines attached to the intake
  17. Dec 22, 2016 at 6:52 PM
    kmcmahon5
    B.C.
    Hmm intersting. Good to know, thanks for the info!
    chaosrob likes this.
  18. Dec 22, 2016 at 7:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Just swap your intake and exhaust over to any year motor and you'll be good. That an PS I guess on earlier trucks.
  19. Dec 22, 2016 at 7:37 PM
    kmcmahon5
    B.C.
    That's the plan. Pull my old intake and exhaust. Love your truck and your trip report by the way. And next time you come out to BC, you gotta come to Vancouver Island!
    Blackdawg and DustStorm4x4 like this.
  20. Dec 22, 2016 at 8:48 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Is there some wheeling trails on the island?
