1996 Tacoma LX 4x4 V6 $5,000
Discussion in 'Buy / Sell / Trade' started by 12guns, Jan 10, 2010.
  1. Jan 10, 2010 at 8:10 PM
    12guns
    12guns [OP] Member
    Evan
    Rville, AR
    96' Tacoma 4x4
    283k miles, runs great. Doesn't drip or burn any oil. I've personally owned this truck since 99' w/ 44k miles. I've driven the heck out of it and kept up w/ oil changes every 3k miles religiously. The engine has a "tick" that is a valve that cannot be shimmed enough to keep it quiet, but after 6 years of "ticking" I wouldn't be too worried about it. Transmission is strong, never slips. Few dings on the outside, but original paint. Mostly highway miles.
    The truck is used and has high miles. I'm selling cause I'm in need of a bigger truck to accomodate my dog! It's not a cream puff, but to give you an idea how I've maintained it, the original Toyota ujoints are still tight and have been greased up every other oil change. Running 32x11.50 Maxxis Bighorn tires w/ about 30% tread left. Custom welded reciever hitch. Everything works as should. You'll get 17 mpg w/ the large mud tires. Best I've ever got was 21.6 w/ 31x10.50 AT tires.
    This is a heck of a truck and I hate to see it go, but I'm ready to upgrade to a bigger truck. Retail is 7900, Rough trade in 4000. They are all over the web for 6000 and higher, I'm asking $5000. I'll include the balljoints and right wheel bearing but you'll have to install them. The truck does have high miles and an engine that ticks, but is still a solid running truck. I have made several trips since November 200+ miles away to duck hunt while pulling my 4wheeler. I'm pricing this truck to sell. It's as is, but of course you'll need to come look at it and see for yourself that it's a solid truck. Org eng and trans.
    Here's a list of the stuff that's been done in the past two years...
    -Brand new leaf springs (two months)
    -Brand new starter
    -new headlights (old ones too dim)
    -Spark plugs and wires
    -timing belt 15k ago
    -left frt wheel bearing
    -brake pads
    -power steering pump
    -belts
    -rear end rebuilt at about 240k miles
    -Trans drain and fill
    -Dropped trans pan to clean
    -inner tie rod ends
    -outer tie rod end left side
    -control arm bushings
    -rack and pinion bushings
    There is more stuff that's been done, but my list is at my office! I'll update tomorrow.
    now for the bad...
    -needs right front wheel bearing (comes w/ the truck not installed)
    -needs both ball joints (also comes w/ truck)
    -Engine valve as mentioned
    -driver's seat has 6 inch tear
    -minor door dings here and there.
    -Stripes are peeling w/ age
    -steering wheel has chunk missing from wear.
  2. Jan 10, 2010 at 8:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  3. Jan 10, 2010 at 8:32 PM
    12guns
    12guns [OP] Member
    Evan
    Rville, AR
    96' Tacoma 4x4
    working on the pics, check back tomorrow and I'll add what I can.
  4. Jan 11, 2010 at 6:53 PM
    12guns
    12guns [OP] Member
    Evan
    Rville, AR
    96' Tacoma 4x4
    Here's a couple. Getting detailed tomorrow, I'll try to add more.
    Anyone interested, let's talk offers.
  5. Jan 11, 2010 at 6:59 PM
    12guns
    12guns [OP] Member
    Evan
    Rville, AR
    96' Tacoma 4x4
    dropped price to $4500 firm due to the tear in the seat and arm rest...bedliner was sprayed on by yours truely and as you see chipped up bad. Ask any questions you want. Would love to start shopping for my Tundra!
  6. Jan 11, 2010 at 7:14 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    looks good from the outside, but I really dont see $4,500.
    When I Kbb'd my truck a while back, and its got over 100K less then yours, they were telling me it would be worth like 2500.
  7. Jan 12, 2010 at 6:12 PM
    12guns
    12guns [OP] Member
    Evan
    Rville, AR
    96' Tacoma 4x4
    Well, I've cleaned it up and it looks much better. NADA decoded w/ vin number and options/mileage says 4000 rough trade in up to 7900 retail.
    I have located a 4runner that I want, but I'll need $3500 out of my truck to make it happen.
    NEW PRICE $3500 FIRM. I'll throw in the balljoints and wheel bearing if it sells fast enough. A dealership told me today trade in should be no less than 3k. Having said that I know it has high miles and is not a cream puff. Otherwise it would be 5k. I'll be putting a sign on it tomorrow for local sale. Let me know if anyone is interested. Thanks
  8. Jan 13, 2010 at 11:52 AM
    hashemg
    hashemg Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    retail price is the price a licensed dealer would sell it for who are required to warrenty their vehicles for at least 30 days.
    the accurate price for a private sale is through kbb.com. but don't ge tme wrong....3500 is a fair price for a 96. i've seen 1991-1992 in MA gor for 3000 (much less miles though)
    good luck w the sale
    I may not have every option listed i tried the best i could
    http://www.kbb.com/kbb/UsedCars/PricingReport.aspx?YearId=1996&Mileage=283000&VehicleClass=UsedCar&ManufacturerId=49&ModelId=300&PriceType=Private+Party&VehicleId=9835&SelectionHistory=9835%7c32230%7c01844%7c0%7c0%7c359601%7ctrue%7c359609%7ctrue%7c359619%7ctrue%7c359624%7ctrue%7c359628%7ctrue%7c359672%7ctrue%7c359641%7ctrue%7c359844%7ctrue%7c359690%7ctrue&Condition=Good&QuizConditions=
    Good luck
  9. Jan 13, 2010 at 11:58 AM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    not interested got mine in the driveway.
    4500 sound decent since you cant touch something like that around here for less then 5k.
  10. Jan 13, 2010 at 2:41 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Good truck and good price...people need to knock off this "your pricing it too high" stuff. It ain't your truck and he didn't ask for your opinion. Don't like the price move along or PM him. This is more than a reasonable price for this truck in this market.
    Bump and +1 rep for the guy.
  11. Jan 13, 2010 at 2:47 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    x2
  12. Jan 13, 2010 at 2:48 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    x2.
  13. Jan 13, 2010 at 4:17 PM
    12guns
    12guns [OP] Member
    Evan
    Rville, AR
    96' Tacoma 4x4
    Thanks for the bumps guys
    I put a sticker in the window today $4200, I'll come down to 3500 cash for local sale. It is a heck of a deal. If nothing else, it's a heated and cooled 4wheeler!
  14. Jan 13, 2010 at 6:30 PM
    rustyshakelford
    rustyshakelford Well-Known Member
    Brett
    Magnolia, TX
    i bought my 96 with 210,000 miles for 5800. i think your price is excellent if not a little to low. loan value is in the 7s
    good luck with the sale
    brett
  15. Jan 13, 2010 at 6:56 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    I agree with the recent posts, Evan. I'd be all over it for that price. Wish I had 3500! Good luck with the sale.
  16. Jan 16, 2010 at 10:29 PM
    gofas
    gofas Well-Known Member
    Russell
    Ukiah
    4x4 Timberland Mica Access
    ImMrYo review mirror bracket.
    yeah dude,
    I paid 5k for mine. the only perk was that it has a 80k engine. otherwise it's a well used truck.
    nice price on your truck. best of luck!
  17. Jan 26, 2010 at 11:00 AM
    12guns
    12guns [OP] Member
    Evan
    Rville, AR
    96' Tacoma 4x4
    Well, traded in on my 05' V8 4x4 4Runner! Got a whopping $2500 trade in. Not too bad considering they came down to 14500 on the 4runner w/ right at 100k miles. Retail on the runner was/is 19500.
    Thanks for the help trying to sell it.
    I almost cried when I had to leave her at the lot...oh well.
  18. Jan 26, 2010 at 11:04 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    wait...you got $2500 for teh 96 tacoma?
    nice!
  19. May 20, 2012 at 2:04 AM
    96 tacomaPtown
    96 tacomaPtown Well-Known Member
    Bryan
    Oregon
    96 ext cab 4x4 taco
    3 inch spacer lift,pro comp addaleaf, 1 inch diff drop kyb shock/struts, Lc engineering header, stock muffler, hollowed cat, 2 1/4 exhaust, o2simulator , 31 10.50 15 wranglers on stock. Hella 500 headlamps, bug gaurd, vent visors, bed caps, bed liner, Volant cai intake.
    yeah you could put it up for 2500 kbb but thats only what id take if i was trading it in to a dealer. any toyota 4x4 extra cab is worth more than 2500 bucks. id start at 5 and deal down from there its a toyota they run a long time if maintained especially tacomas. i see toyota pickups with "rebuilt" 3.0 liter v6s notorious for failed head gaskets for for 5 all the time. I wouldnt settle on 2500 thats Kelly Blue Book who ever prices vehicles on that is very innacurate with what the man says and what price on the street is. i have never purchased a vehicle at or below kbb. Its always several thousand more. every toyota ive owned has been that way and everone knows " ITS A TOYOTA THEY RUN FOREVER" best track record. so if you settle on selling for 2500 someone with a rebuilt is going to love that.
  20. May 20, 2012 at 4:48 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    Thread is only 2 years old
