1996 Tacoma Slave Cylinder ?
Discussion in 'Technical Chat' started by Fishinguy, Aug 16, 2010.
  1. Aug 16, 2010 at 8:24 AM
    Fishinguy
    Fishinguy [OP] New Member
    Guy
    North Carolina
    1996 Toyota Tacoma A-Tra Cab 4x4
    I have a 1996 Tocoma X-Tra Cab 4X4 with the 2.7 motor. Last year I had the clutch replaced. Recently I have been having to add brake fluid to the slave cylinder resevoir. In fact I filled it on Saturday and did not use the truck all weekend. I checked it this morning and the resevoir was dry. When I fill it and pump the clutch up it works fine. Does this usually mean that the slave cylinder needs replacement or is it possibly a leak in the line? This appears to be an easy fix. However, I have never done it and any advise would be appreciated. What else if anything should I look for?
  2. Aug 16, 2010 at 8:30 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You should see where the fluid is leaking before you replace anything. Thats a lot of fluid to leak just sitting there.
  3. Aug 19, 2010 at 5:33 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    x2
    If it's been leaking that much fluid it should be pretty easy to find the puddle. Don't forget to check the driver's side floor under the clutch pedal for leaks from the master cylinder.
