1996 toyota Tacoma 2.4 pickup I DROVE TO STORE CAME OUT DEAD NO SPARK
Discussion in '1st Gen. Tacomas (1995-2004)' started by oldguy128, Sep 13, 2020.
  1. Sep 16, 2020 at 8:58 AM
    #41
    oldguy128
    oldguy128 [OP] Well-Known Member
    GARY
    Southbury CT
    1996 Toyota Tacoma
    I did
  2. Oct 7, 2020 at 12:38 PM
    #42
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    Any update?
  3. Oct 7, 2020 at 1:24 PM
    #43
    oldguy128
    GARY
    Southbury CT
    1996 Toyota Tacoma
    FIXED Well, I must admit I'm not a LICKY GUY
    Ok the first thing to know I'm a retired electronics tech, and a C-band satellite installer repair guy I screwed myself the whole problem was a missing voltage going to the igniter Sadly I had to pay a mech to find that issue
    When I removed the connector which was the very first thing I did the voltages checked out BUT I DID NOT SHAKE THE CABLE AND WHEN I PUT THE CONNECTOR BACK ON IT WENT TO OPEN BROKEN WIRE AGAIN
    NEVER BUY SPECTRA PREMIUM DIST
    THE FIRST ONE THE CAP WOULD NOT EVEN CLOSE THE ROTOR STUCK UP TO HIGH
    THE NEXT ONE MADE THE TRUCK RUN POOR
    I WENT BACK TO my old DIST
    Now I got a broken cable to the CAM sensor it broke when I went to check it
    Dalandser and DrZ like this.
  4. Oct 7, 2020 at 1:29 PM
    #44
    JudoJohn
    St. Louis
    Thanks, Gary. I'm glad you figured it out. Sorry about the CAM sensor
    oldguy128[OP] likes this.
  5. Oct 7, 2020 at 4:56 PM
    #45
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Do you mean the crank sensor?
    The cam sensor is built into the distributor on 1996 model year with distributors (the 4-cylinders). There was a separate cam sensor mounted in the middle of the head when Toyota went to coil packs a year or two later.
  6. Oct 7, 2020 at 8:58 PM
    #46
    oldguy128
    GARY
    Southbury CT
    1996 Toyota Tacoma
    It's on the block near the front on driver side connector had green crap this truck was once hit bad from the guy I bought it off My guess rain got in even the connector on the DIS looked crappy I cleaned it up
    OK, where do I buy the right rear step bumper for this truck black color is fine, the old one is rusted out the frame was never swapped out I only wish it was I tried after I bought it no way they would do it?
