1996 trailer wiring
Discussion in 'Lighting' started by c00lfloyd, Aug 23, 2010.
  1. Aug 23, 2010 at 10:21 PM
    c00lfloyd
    c00lfloyd [OP] Member
    Rob
    The Dark Side of the Moon
    1996 Tacoma 2WD 2.4L
    17" 5 Star Rims, 225F - 235R
    Hey all, i tried searching all over, but couldn't really find what i was looking for.
    So here goes..
    I have a 96 taco, 2.4l 2wd, auto.
    I am going to take it down to FL this weekend.
    I get the task of helping my sis move back up here to MI.
    so, the plan is when i get down there to get a uhaul trailer er sumthin, and load all her stuffs up and drive it back up here.
    I have added the 2" ball to the rear bumper, but now i have to add the trailer wiring.
    Now I'm sure you all are gunna say go get 1 of them kits for this truck., and yes normally i would, but $ is gunna be REAL TIGHT on this trip, and from what i've found, them kits are $40.
    and i don't think i can do that now. (as it is, I've already had to do a oil change, and 4 new shocks for this trip) not to mention the gas I'm gunna need, etc...
    So, i need to know how i can wire in the 4 pin connector directly into the truck wiring myself? is it even possible?
    What concerns me, is that this truck has separate turn signal lights from the brake lights. which is going to cause a problem with direct connections.
    I'm thinkin maybe a few diodes in the right spot might fix that. but i'm not sure, that's why I'm askin here! :)
    If there's just no possible way to do this manually, I'll just have to cough up the xtra $ and get the kit... but at this point any $ i can save helps alot.
    thanx alot for your help & time!
    -R
  2. Aug 27, 2010 at 1:12 PM
    c00lfloyd
    Rob
    welp, i didnt expect many responses to this... maybe at least sumthin like
    " are you that cheap, just go buy the dam kit and do it right!"
    so, i'm taking the advice i never got, and just got a kit..
    i'm about to install it here this evening or tomorrow.
    i'll report back on how it went...
    -R
  3. Aug 29, 2010 at 5:27 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Too late now I know, but you can get univeral kits that you still splice in to your existing wiring.
    You have to have a converter to change the seperate signals into combined brake and turn lights. They are relatively cheap compared to buying one with the direct plug in connectors.
    The last option would be to just buy a four flat trailer plug and splice it to the brake lights. Then at least you'd have brake and tail indication on the trailer, just no signals.
