1997 Frame Rehab Thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by DBowers01, May 21, 2018.
  1. Apr 3, 2019 at 11:06 AM
    #141
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    I don't but if i come across some Ill hit you up
  2. Apr 3, 2019 at 11:21 AM
    #142
    GQ7227
    GQ7227 mw survivor
    J A Y
    did the original owner NOT have the undercoating package done before they drove it off the lot in '97 :confused:
    i will have to spend the weekend on this thread
  3. Apr 4, 2019 at 5:16 AM
    #143
    DBowers01
    DBowers01 [OP] Well-Known Member
    Dan
    I have no idea about the original owner. I got it from the second owner.
    Thanks for the interest in the rebuild...the short version is the truck was junk from the cab to rear bumper. A potato chip has more structural integrity than the frame did. I actually bent the frame when tying it down on the trailer to bring it home. After sourcing parts from Tour991 I was able to rebuild everything and section in a new frame from the transfer case cross member to the rear and reuse all factory parts. Since the truck was free, it was worth it. Total investment is around $2k including the new bed and everything else mentioned in the thread.
    Riding Dirty and GQ7227[QUOTED] like this.
  4. Apr 4, 2019 at 3:21 PM
    #144
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    Awesome!!! Now fluid film the crap outta it and it should be good to go for a long time.,!
  5. Jun 19, 2019 at 4:49 AM
    #145
    Sandy94
    Sandy94 Well-Known Member
    The Commonwealth
    Toyota Tacoma
    I got mine for my '96 here:
    https://www.bushwacker.com
  6. Jun 19, 2019 at 6:45 AM
    #146
    Dhearic
    Dhearic Member
    NW Arkansas
    97 4X4 3.4L Auto
    This has been a fantastic build to learn from. Good job and thank you for posting it
  7. Jun 3, 2022 at 6:57 AM
    #147
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    I know this is an old thread revival, but I'm about to do this same project on my truck and I want to thank you @DBowers01 for this detailed thread. Do you have any sage advice to pass on after having done it yourself? I'll be replacing the rails like you did but retaining my cross-members and hopefully just supporting the axle/drivetrain in place. My brother is a welder and he'll be doing the welding. One question I have is, did you run into any issues trying to weld the frame with the cab still in place? I don't want to remove my cab if I don't have to. Were there any problems trying to weld the topside?
  8. Jul 2, 2022 at 9:34 PM
    #148
    DC92T
    DC92T Well-Known Member
    03 TACO 33" BFD's SLOWPOKE
    Suspension lift, towing package with air bags rolling on 33" BFG A/T's
    When I chop frames to mate them I stagger the joint 90 degrees differently than you did, so there is strength to the frame when weight is on top of it. A slice in the middle on the outer side of the "C" and I take a 1 foot length splitting the center of that cut on the opposing "C" of that frame rail, repeat on the other side. Before I slide in the 12" piece I gusset inside the frame to add some more strength. You added some more bracing later on in this thread anyway, that's just what I came up with and it's always seemed to work well.
  9. Jul 2, 2022 at 10:22 PM
    #149
    DC92T
    There was a 3" body lift on the Taco I did so I could get in there easily for welding. But, you can just remove the 4 cab mount bolts and loosen the front 2, jack it up with some wood on the cab corner and you 'll have plenty of room. I caught your thread too, I think you already cut one section and rejoined it (the unboxed frame portion) but I'd chop it differently as I mentioned above for more strength, if you still can. And where you cut your frame for shipping purposes you may be able to box in the other side with a nice wide piece of 3/16ths or .1875 plate. Your post is a month old, you may have already got to it...
  10. Jul 4, 2022 at 5:05 AM
    #150
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    Come to my thread and lets talk more. I will soon post my jack/support plan with pics.
