1997 Taco Not Getting Fuel??
Discussion in '1st Gen. Tacomas (1995-2004)' started by weltonrs, Sep 23, 2012.
  1. Sep 25, 2012 at 11:29 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Double check your wiring. Sounds like that is the issue to me.
  2. Sep 25, 2012 at 12:05 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Do the injectors "click" when you crank the engine? You should be able to hear them trying to do work if they are wired correctly. As suggested, I would once over the fuel system connections before I sent out my injectors. Down time lost.
  3. Dec 10, 2021 at 2:04 PM
    Gordo88
    Gordo88 Member
    Gordon
    97 Toyota
    What was the fix for this? I’m having the same issue! New injectors, plugs, wires, fuel filter and fuel pressure regulator. I’m getting fire and with my meter on the injector plug I’m seeing 12v on the + side and pulsating negative battery signaling the injector to fire but seems weak. I have 40-44 PSI on the fuel rail while turning over. Any help is greatly appreciated.
  4. Oct 17, 2023 at 11:53 PM
    CalderFH
    CalderFH Member
    1995.5 Tacoma Xtra Cab 2.4l 2rzfe
    Gordo88 did you ever fix yours? My 95 2.4 quit while driving and now won't catch when I crank it. Fuel all the way to FPR, but none from return. Replaced a dead injector and ultrasonic cleaned the other 3 about 4 months prior. Fuel pump pumping but pressure unknown.. fuel pressure gauge is one of the few tools I don't own. Fires off starting fluid. Crank position sensor is good via multimeter. New NAPA fuel pump arrives tomorrow, $30 cheapo...... we'll see
  5. Oct 18, 2023 at 9:06 PM
    CalderFH
    CalderFH Member
    Update: it was the gall darn fuel pump. Put the new one in and it fired up on the second crank. So, yes, they can absolutely still pump but not have enough pressure to overcome the fuel pressure regulator.
    Kevins60 and Steves104x4 like this.
