1997 Tacoma 4x4 Problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by ctm907, Feb 24, 2012.
  1. Feb 24, 2012 at 7:45 PM
    ctm907
    ctm907 [OP] Member
    Connor
    Kodiak Alaska
    Lifted 2 in, After Market Exhaust, 2 Kenwood 12's, 31 in tires
    My 1997 Toyota Tacoma will not engage in 4x4. when i press the button the 4x4 light does not go on but it does make the clicking sound. I can here the actuator make a noise too. i took one of the vacuum hoses off of the actuator and there is no suction coming to or from the actuator. Do I need a new actuator? Please help
  2. Feb 25, 2012 at 10:05 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Can you hear the transfer case sound like it shifted? I don't think it's an actuator problem...
  3. Feb 25, 2012 at 1:39 PM
    ctm907
    ctm907 [OP] Member
    Connor
    Kodiak Alaska
    No I cant hear the transfer case make any noise. Only actuator when the button is pushed.
  4. Feb 25, 2012 at 1:48 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    im going to say that it is going to be pretty hard to diagnose your problem on a complicated system like the 4wd train over the internet unless you provide a whole lot of specific details and trouble shoot scenarios
  5. Feb 25, 2012 at 1:57 PM
    ctm907
    ctm907 [OP] Member
    Connor
    Kodiak Alaska
    well how much more detail? the 4x4 does not work what so ever. No 4 lo or hi. the actuator seems to work becuase it makes a noise. I never opened up the differential.
  6. Feb 26, 2012 at 8:22 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    There is a actuator on your front diff to the passenger side of the diff's nose. You have to be looking from the back of the truck to the front. Make sure everything is connected. When my 4x4 did not work there was a vacuum hose was disconnected.
  7. Feb 26, 2012 at 1:31 PM
    ctm907
    ctm907 [OP] Member
    Connor
    Kodiak Alaska
    I just checked and all hoses are connected.
  8. Feb 26, 2012 at 2:12 PM
    ctm907
    ctm907 [OP] Member
    Connor
    Kodiak Alaska
    I have the sr5 which has the push button 4x4 knob with auto locking hubs
  9. Feb 26, 2012 at 2:44 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I have nothing to add to this conversation, but I just wanted to say hi from Anchorage. Always nice to see a fellow Alaskan on the forum :)
    Good luck with your issue.
  10. Feb 26, 2012 at 3:07 PM
    ctm907
    ctm907 [OP] Member
    Connor
    Kodiak Alaska
    Yes
  11. Feb 26, 2012 at 3:12 PM
    ctm907
    ctm907 [OP] Member
    Connor
    Kodiak Alaska
    I also removed the vacuum hose to the actuator and engaged the 4x4 and it makes the same exact sound when i engage the 4x4 with the hose on the actuator. I dont know if this helps or not.
  12. Feb 26, 2012 at 3:17 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    Well I wish I could help you with this, but I even double checked my VIN, (I had a stroke and have memory problems) but my 96 is sr5 and it had electronic 4wd, but it is manual, from what i had read, i did not think they added the push button several years later. 4wd systems are nothing to mess around with unless you really know what you are doing. Toyota's are very reliable, even with half/ass care, I would check with a shop.
  13. Feb 26, 2012 at 3:19 PM
    ctm907
    ctm907 [OP] Member
    Connor
    Kodiak Alaska
    Yeah I think its only on the sr5. All of my friends who dont have the sr5 dont have the push button autolocking hubs and sun roof. i have power mirrors, locks, and windows as well.
  14. Feb 26, 2012 at 4:43 PM
    goomba
    Josh
    San Antonio Fl
    I have a 96 mt with a push button nob. Hey your 4x4 light can burn out. Have you tested ur 4x4 in any other way?
  15. Feb 26, 2012 at 5:09 PM
    ctm907
    ctm907 [OP] Member
    Connor
    Kodiak Alaska
    Yeah on ice in a parking lot. only the rear tires spin. i need to get a running start if i go up a hill with snow/ice. I have been driving all winter in 2wd since it hasn't worked for me. I just put sand bags in the back but i would really like to do some off roading during the summer and i need 4x4 for that
  16. Feb 26, 2012 at 5:13 PM
    goomba
    Josh
    San Antonio Fl
    Ya i hear ya. If I am guessing that you have gone in reverse trying toengage it. Have you checked the fuses? The 4x4 system is both electric and vacuum activated.
  17. Feb 26, 2012 at 5:29 PM
    ctm907
    ctm907 [OP] Member
    Connor
    Kodiak Alaska
    Yeah I both checked the fuses and tried putting 4x4 while in reverse and no luck still
  18. Feb 26, 2012 at 5:31 PM
    goomba
    Josh
    San Antonio Fl
    ok I am looking in my haynes manual trying to find something.
  19. Feb 26, 2012 at 5:48 PM
    ctm907
    ctm907 [OP] Member
    Connor
    Kodiak Alaska
    Okay thanks. keep me updated
  20. Feb 26, 2012 at 6:22 PM
    goomba
    Josh
    San Antonio Fl
    First it has u making sure all vacuum lines are connected, then It has you checking the resistance of the front actuator and the ADD solenoids(37-44ohms).
    Replace if needed. Sorry not much help, but i can take pictures of take video of the section if needed.
