1997 Toyota Tacoma 3.4 4wd transmission issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Judd4x4, Jan 25, 2025.
  1. Jan 29, 2025 at 6:45 AM
    getouttamyway
    getouttamyway Member
    SF Bay
    1996 SR5 V6 4X4
    Have you inspected your flex disc? It's hella loud if it's broken but take a look inside the inspection plate.
    I just had my box rebuilt for $2500 including a new TC fyi
  2. Jan 29, 2025 at 8:22 AM
    Judd4x4
    Judd4x4 [OP] Member
    1997 Toyota Tacoma
    No, I almost did it last night but I thought man that should be making alot of sound. And would it still start easy. Cause the engine is starting and running good.
  3. Jan 29, 2025 at 9:07 AM
    getouttamyway
    SF Bay
    1996 SR5 V6 4X4
    Good point it wouldn't start if the flex disc broke. Unless the bolts going to the TC popped out but I couldn't imagine that happening.
  4. Jan 29, 2025 at 9:26 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If you can do the work yourself, it may be way more cost effective to swap in a used one. Where abouts are you located?
    Do a search for one at this place: https://www.car-part.com
  5. Jan 29, 2025 at 9:56 AM
    Judd4x4
    Judd4x4 [OP] Member
    1997 Toyota Tacoma
    I'm in the Cleveland, Chattanooga, Knoxville, TN area 423
  6. Jan 29, 2025 at 11:18 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Did you do a search using their search tool? It looks like there might be some options for you.
    In general, a good used one will cost you alot less than a rebuild. Of course there is some risk going either route.
