1998 2.7L V4 Tacoma is gutless.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blackout7of9, Feb 8, 2017.
  1. Feb 8, 2017 at 2:34 PM
    Blackout7of9
    Blackout7of9 [OP] Member
    No, I think the clutch is ok.....I hope
  2. Feb 8, 2017 at 2:35 PM
    Blackout7of9
    0-60 in 11.5
  3. Feb 8, 2017 at 2:35 PM
    Burnett
    Burnett Well-Known Member
    Nolan
    North Georgia
    98' Xtra cab v6 4x4 evergreen pearl
    Bilsteins 5100's & 5125's, OME Dakar leafs Custom toolbox Custom bedstep/towhook/reverse light combo Custom Bedrack
    Get the service manual from the parts store and your plugs filter etc online or from Toyota dealer. Get Toyota parts and do the tune up yourself. Save a buck and have the satisfaction of doing it yourself.
    Toyko Joe likes this.
  4. Feb 8, 2017 at 2:36 PM
    Blackout7of9
    Yeah I guess i need to look into a tune up
  5. Feb 8, 2017 at 2:37 PM
    Blackout7of9
    hahahahahhahahhahahahahhaahaah Yes, I know a 2.7 is small but I didn't think it would be that bad.
  6. Feb 8, 2017 at 2:37 PM
    Blackout7of9
    Great advice I try to do most things myself. I will!!!
  7. Feb 8, 2017 at 2:38 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    11.5 seconds is "tons of power" to you?????
    ayyyyy vey.
  8. Feb 8, 2017 at 2:40 PM
    hortona
    hortona Well-Known Member
    99 tacoma SR5 w/ 3rz-fe
    11.5 secs beats my clocked in 38 seconds
  9. Feb 8, 2017 at 2:41 PM
    hortona
    A tune up should definitely help.. one time I did a zero o sixty and it took over thirty seconds. Plugs, wires, filters and than I got 18 still slow but much better
  10. Feb 8, 2017 at 2:43 PM
    Toyko Joe
    Toyko Joe Here for the pictures
  11. Feb 8, 2017 at 2:44 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    SUPERCHARGE THAT BITCH!!!!
    You're welcome.
  12. Feb 8, 2017 at 2:49 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  13. Feb 8, 2017 at 3:16 PM
    Blackout7of9
    Yes, to me that is a lot
  14. Feb 8, 2017 at 3:16 PM
    Blackout7of9
    Ouch your time is close to mine at 30
  15. Feb 8, 2017 at 3:20 PM
    #35
    Blackout7of9
  16. Feb 12, 2017 at 4:43 PM
    #36
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    my 99 2.7 drives like a wet dog also. mine has tons of blow by though. can i just supercharge a motor with low compression? iv heard that you need lower compression with forced induction.
  17. Feb 12, 2017 at 5:06 PM
    #37
    chaosrob
    chaosrob Well-Known Member
    I just wonder if any of these people actually drove it before buying it. It should really not be any kind of surprise to anyone who went on a test drive before plunking down the cash
  18. Feb 12, 2017 at 7:42 PM
    #38
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    LS1 swap.
    But seriously, it's a 4cyl. It ain't no power house. I had a 97 5 lug with the 4cyl 5 speed. It did "okay" in that I didn't expect to beat a Lotus in the 1/4, and I got 28-30 mpg.
    You running stock tires, is it a 4wd?
    Also, why are you trying to start out in 3rd??
    Definitely go thru a full tune up, though.
  19. Feb 12, 2017 at 7:57 PM
    #39
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    Negatory, ghost rider. A supercharged engine may have a lower compression ration, but that doesn't mean it has blow-by. Adding a supercharger to a worn engine with low compression means that the oil just blows by the rings faster.
  20. Feb 13, 2017 at 7:53 AM
    #40
    Toyko Joe
    He tried starting in 3rd to see if the clutch is failing, because that is the test in the link I previously posted.
