1998 3.4L V6 "Does anyone know what this plugs into?"
Discussion in 'Technical Chat' started by yoTaco98, Jul 3, 2011.
  1. Jul 3, 2011 at 1:05 PM
    yoTaco98
    yoTaco98 [OP] Well-Known Member
    Yo
    VA
    1998 V6 Xtra-Cab Tacoma 4x4 SR5
    5100's Front and Rears, Toytec Eibach Coils, All Pro 3" Standard Leafs, BAMF BPV Bracket, ARMA Sprayed Bedliner, TGD Hunter Bull Bar, Blacked-out Headlights and Corners, Revtek 1" Diff Drop, Start Command Remote Start and Keyless Entry, Pioneer DEH-11E HU...
    I had to replace the gasket on my valve cover, and plugged everything back up when I was done, but this plug didn't have a male end to plug into.
    I can't remember, But I think that it doesn't plug into anything.
    Could some one please help me confirm this.
    Or take a pic of your engine for me, around the throttle body area to visually confirm.
    Thanks in advance guys!
  2. Jul 3, 2011 at 1:14 PM
    big dog
    big dog Hug balls bitch
    Las Vegas
    03 SR5 TRD 4X4
    OME 3" k&n cai magnaflow muffler all pro front bumper 4x innovations rock sliders moto metal wheels with 33" Bridgestone dueler revo 2 AT tires
    sometimes there is wiring that has no place it might be there for a option your truck did not come with they build all the wiring harness the same and the trucks options difer if you dont remember taking it off chances are it has no place does everything work and it starts if so you should be good
  3. Jul 3, 2011 at 1:17 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    i went and looked at mine. and didnt find a triangle lookin plug like that. all mine are square or round.
  4. Jul 3, 2011 at 1:27 PM
    yoTaco98
    Yo
    VA
    Every plug has it's own shape, so you can't connect the wrong plugs.
    But usually the unused one, is tape back.
    If you look at the gray plug to the right of it...that one is taped down, but had it's own plug.
    This one was not.... very odd. They are both on the same harness section.
  5. Jul 3, 2011 at 1:31 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Judging by how very dirty the inside of that connector is, I would have to say that it doesn't plug into anything on your truck.
  6. Jul 3, 2011 at 3:14 PM
    yoTaco98
    Yo
    VA
    Check engine light came on....
    I pulled over and went through the engine again.
    I found the opposite end behind the plastic timing belt housing, toward the very top.
    Went to Advance Auto, they ran a diagnostic and said that knock sensor 1 &2 had an error.
    So I suppose that the plug goes tot he knock sensors.
    They reset the light and it hasn't come on in 10 miles...so we'll see.
    The only thin is that the gray plug has a clip, so it's supposed to clip in to something to keep plug from dangling. I just can't find where it clips in to now.....
  7. Jul 3, 2011 at 5:55 PM
    McBride513
    McBride513 Well-Known Member
    Luke
    Cincinnati
    04 4x4 TRD
  8. Sep 25, 2012 at 4:41 PM
    gjdemar
    gjdemar New Member
    2001 Tacoma 4wd 3.4L V6
    none
    yes - that plug is definitely for your knock sensors. Take off the top timing belt cover and you'll find the cable from both sensors which are located in the valley beneath the intake manifold. You may be able to get from the top with out removing cover. That's why you got your error message for the knock sensors
