1998 Honda civic oil leak
Discussion in 'General Automotive' started by tvbd56, Jul 17, 2013.
  1. Jul 17, 2013 at 7:30 PM
    tvbd56
    tvbd56 [OP] Epic Member
    Tyler
    Sacramento, Ca
    05 AC Prerunner 6-speed
    k&n air filter, weathertech digital fit, TRD 6-speed gray knob, undercover bed cover, flowmaster american thunder dual exhaust, URD short shifter, 5100's set at .85, Grillcraft, black surround grille(with SJ stripe)
    I bought a Honda civic for $550 to use as a commuter and turns out that I have found that there is a small oil leak. The oil pan looks TERRIBLE, it's so dirty with black gunk. I'm not sure where the leak is but my guess is that it needs a new oil pan gasket. Where do you guys think the leak is from? A couple of the pictures were from after I wiped the oil off of the pan in a couple of the pictures.
    https://www.dropbox.com/sc/ms10bj764uhjmfs/P6sTpPa_mZ
  2. Jul 17, 2013 at 7:43 PM
    DaBears
    DaBears Well-Known Member
    CONUS
    10 trd sport
    You can't tell from those pictures. You could try to make sure all of the oil pan screws are torqued to spec. to see if that helps.
  3. Jul 17, 2013 at 7:45 PM
    Bennett707
    Bennett707 TWSS Enforcer
    Oregon
    '04 V6 3.4 TRD
    zip ties and scotch tape
    honda's are pretty easy to work on. I'd just remove the entire engine give it a deep clean and you'd probably find the spot easier if not faster.
  4. Jul 17, 2013 at 8:07 PM
    tvbd56
    Tyler
    Sacramento, Ca
    I'll check the oil pan screws, I would hope it's something as simple as that. If I take the oil pan off do I have to get a new gasket to put the oil pan back on or is it ok to use the old oil pan gasket?
  5. Jul 17, 2013 at 8:10 PM
    Bennett707
    Oregon
    '04 V6 3.4 TRD
    gaskets are normally pretty cheap, I wouldn't want to remove a oil pan twice and potentially lose an entire gallon of oil because of a old gasket.
  6. Jul 17, 2013 at 8:13 PM
    tvbd56
    Tyler
    Sacramento, Ca
    ok thanks for the help, do you guys know of any common problems with this generation of the civics?
  7. Aug 2, 2013 at 5:35 PM
    DaBears
    CONUS
    10 trd sport
    awesome gas mileage is the only one I know of
  8. Aug 8, 2013 at 12:45 PM
    jeepdude
    jeepdude Regular Member
    Jesse
    Connecticut
    2004 ext cab 4x4 TRD, bone stock for now
    $550? Nice...How many miles? Show us a picture! Clean'er up good and then check, most likely from the main seal (crank)
  9. Aug 8, 2013 at 3:32 PM
    tvbd56
    Tyler
    Sacramento, Ca
    I'll get a picture, there were 254,000 miles and now I just rolled 258,000 miles and I looked today and the oil pan is coated with oil:(
