1998 Prerunner - Power Rear Slider (aftermarket?)
Discussion in '1st Gen. Tacomas (1995-2004)' started by leftfield6, Apr 15, 2019.
  1. Apr 15, 2019 at 11:52 AM
    leftfield6
    leftfield6 [OP] New Member
    Lawrenceville GA
    1998 Tacoma Prerunner
    Greeting all, I've got a new-to-me 98 Tacoma Prerunner extended cab I'm fixing up. It's really in great shape, but has a few minor irritants going on.
    One is my rear power sliding window, which I assume is aftermarket. Motor is mounted in the rear passenger side storage area.
    Cable runs up the side behind the trim and then enters the lower corner of the rear window assembly.
    The switch is located to the left of the steering column.
    Problem is, even though the motor runs, nothing happens. As a matter of fact I can push the sliding part of the window back and forth with my hand. It's not attached to anything. it seems like the window has detached from the cable somehow. Anyone seen this set-up before? Any tips on how to disassemble or repair?
  2. Apr 15, 2019 at 1:28 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Everything
    Boy, I haven’t seen aftermarket sliders like that since ths 90’s they are way cool. Does the motor to it make any sound, and did it break when you were using it I can help somewhat as Im not right there.
  3. Apr 15, 2019 at 1:35 PM
    tony2018
    tony2018 Well-Known Member
    had a whole debate on that a while back.
    Crow_of_judgement likes this.
  4. Apr 15, 2019 at 1:36 PM
    Crow_of_judgement
    Crow_of_judgement Judging you.
    William
    League city
    2004 tacoma double cab sr5 4x4
    Snorkel, ome 881s, Dakar leaf pack, magnaflow exhaust, arb front bumper, shrockworks rear bumper
    Good times. Good times.
  5. Apr 15, 2019 at 1:46 PM
    BartMaster1234
    BartMaster1234 American Auto Horns
    Tyler
    San Francisco, California — SFSU
    1998 PreRunner 4x4 1998 5-Lug SR5 v6
    4x4 Conversion Power Door Retrofit '85 DeVille Horns
    How these work is a worm gear system I believe. The motor spins a cable that spins a worm gear on the track of the sliding window. Check to see if the window has engagement with it.
  6. Apr 15, 2019 at 3:28 PM
    leftfield6
    Lawrenceville GA
    Wow, thanks for quick responses!
    Answers:
    • Yes, the motor runs when I engage the rocker switch in either direction. I can hear it, and I can feel it if I put my hand on the motor while pressing the button.
    • I can't quite reach the cable where it runs into the window assembly to see if i can feel the cable vibrating inside, so I'm not 100% sure the cable is moving.
    I really think the issue may be inside the track at the bottom of the window itself. As i said earlier, the middle section of glass slides freely. I think it has become detached from whatever is supposed to anchor it to the cable. And the entire assembly looks to be riveted and bonded together.
    Curious what the "whole debate a while back" was about? Didn't realize I was bringing up a controversial topic. :boink:
  7. Apr 15, 2019 at 3:30 PM
    Crow_of_judgement
    William
    League city
    It wasnt that great.
    Guy swore 1st gens had a factory power slider window, wouldnt accept he was wrong, claimed to build multimillion dollar yachts, but still drove an old tacoma.
    Mildy amusing for a few min
  8. Apr 15, 2019 at 3:51 PM
    leftfield6
    Lawrenceville GA
    Gotcha.
    Yeah, this thing is for sure not a factory part. The motor assembly was mounted in a way that wastes almost half the storage space in the hidden compartment. If I can get it working, i will re-do the install of that part so it's better integrated.
