1998 Taco Noob Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Dec 2, 2009.
  1. Dec 2, 2009 at 3:35 PM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    Hello All-
    Searched the site for awhile and started to get blurry eyed and not finding what I'm looking for.
    First question:
    I have the ever cleverly designed center console/cup holder that has the 3.5" square by 1" deep cup holders that don't hold anything upright. I was told by a Toyota mechanic that I could easily swap out with a 2000-01, with the smaller and deeper round cup holders, as they have the same exact screw patterns as my '98. Can anyone confirm this or provide better advice on how to fix this weakness?
    Second question:
    I've found some good advice on painting my stock alloy 15" wheels on here. They are so beat to hell right now, that I think a cheap rattle can application would be just fine. Every write up I've seen says to take the weights off before painting. I ask, can't I just leave them on so they match the eggshell black I will eventually use? I just got brand new tires put on so it's going to be a while before they need to be balanced again (hopefully)
    Thanks in advance.... plenty more questions to come guaranteed :eek:
  2. Dec 2, 2009 at 3:39 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Answer to the first question: Yes, the holes should be in the same place. My 1996 has a newer interior (either from a 00 or 01) and the holes are the same. So IMO, should still fit.
    2nd question: I suppose that's up to you, depending on how quality of a paint job you want. I guess.
  3. Dec 2, 2009 at 3:55 PM
    Madjik_Man
    Boulder, CO
    Thanks. Now I have to try and find a matching center console, but I'm stoked it should work.
    As for the wheels question, I want it to look good, as best as my amateur abilities will get me, but I was mostly wondering if it's a bad idea, for some reason, to paint the weights :notsure:
  4. Dec 2, 2009 at 3:59 PM
    STLharry
    Harry
    VT
    I wouldn't see why it would be a bad idea. Maybe ask around to the members who have painted their wheels, but idk why it would be bad.
  5. Dec 2, 2009 at 4:03 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    i painted over mine when i did it way back when
    downside is youll have to do a touch up when you get them rebalanced
    you could maybe mark the tire where the weights go with some chalk and then replace the weights when youre done
  6. Dec 2, 2009 at 4:11 PM
    Madjik_Man
    Boulder, CO
    Thanks.
    I don't mind the touch up. Honestly the wheels are so beat up now, that anything would be an improvement.
    Any pics of your wheels?
  7. Dec 2, 2009 at 4:16 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    What are the weights for?
  8. Dec 2, 2009 at 4:17 PM
    Madjik_Man
    Boulder, CO
    To balance the wheels
  9. Dec 2, 2009 at 4:34 PM
    Madjik_Man
    Boulder, CO
    We can go all the way up to an '04 and have the same screw holes?
