1998 Tacoma 5.3L Vortec (LS) Engine Swap Thread
Discussion in '1st Gen. Builds (1995-2004)' started by jimmy johnny, Jan 20, 2020.
  1. Jan 21, 2020 at 8:14 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Nice work so far. Obviously have mechanical skills. Look forward to your progress. :hattip:
    jimmy johnny[OP] and six5crèéd like this.
  2. Jan 21, 2020 at 8:23 PM
    jimmy johnny
    jimmy johnny [OP] Well-Known Member
    1998 Tacoma
    Disconnect fuel lines
    Disconnect engine wiring harness from computer in the cab
    Remove heater lines at firewall (try not to crush the tube, doh!)
    Remove alternator, hang to the side
    Remove power steering pump, hang to the side
  3. Jan 21, 2020 at 8:27 PM
    jimmy johnny
    1998 Tacoma
    Support drive shaft with jacks and loosen the bolts at the rear diff, center carrier bearing, and transfer case
    Drive shaft removed
    six5crèéd likes this.
  4. Jan 21, 2020 at 8:35 PM
    jimmy johnny
    1998 Tacoma
    Remove driveshaft between transfer case and front diff (4WD), also remove automatic shift lever while your close to it
    Loosen bolts at transmission crossmember (PB Blaster might be required)
    six5crèéd and RangeDrive like this.
  5. Jan 21, 2020 at 8:35 PM
    RangeDrive
    RangeDrive Well-Known Member
    02 V6 Double cab
    Icon front end, OME Dakar rear, ARB front bar
  6. Jan 21, 2020 at 8:42 PM
    jimmy johnny
    1998 Tacoma
    Disconnect anything else connected to the engine that is also attached to the body (air cleaner, throttle cable, cruise control). Loosen engine mount bolts. I will be pulling the engine, transmission, and transfer case all together!
    Bring in engine hoist and load leveler. I believe I attached to the power steering and alternator mounting points in the front. There is a factory lift point back right. Back left I went all the way to a bolt near the transmission.
    Make sure to unbolt the exhaust at the coupler left side of engine, cat back exhaust can stay in during engine extraction
  7. Jan 21, 2020 at 8:53 PM
    jimmy johnny
    1998 Tacoma
    Start the lift and tilt
    Keep an eye on the back end, support with a floor jack
    I made the mistake of not removing the 4WD transfer case shifter first, make sure to do that before starting the lift.
    BeLance89 and six5crèéd like this.
  8. Jan 21, 2020 at 9:00 PM
    jimmy johnny
    1998 Tacoma
    Start to inch everything forward, slowly (view of transmission)
    Kinda tight at the back, make sure to clear the automatic shift lever
    A pretty extreme tilt is required, factory lift point visible in this image
  9. Jan 21, 2020 at 9:07 PM
    jimmy johnny
    1998 Tacoma
    View below the transmission oil pan, down to the front diff, caked in oil from the leaking head gasket
    View from the back, guiding the transfer case over the front diff
    Almost out, just need to clear the front support
    six5crèéd and 20tacoma17 like this.
  10. Jan 21, 2020 at 9:14 PM
    jimmy johnny
    1998 Tacoma
    Max out the crane and a few extra pulls and she is out!
    And then on to a pallet where the transmission and transfer case can be easily separated.
    six5crèéd and BikerinBlak909 like this.
  11. Jan 22, 2020 at 5:08 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    This is going to be an awesome ride when you're finished. Thanks for sharing!
  12. Jan 22, 2020 at 8:56 PM
    jimmy johnny
    1998 Tacoma
    Empty engine bay
    Transfer case separated
    Transmission separated
    Biscuits, Sacrifice and six5crèéd like this.
  13. Jan 22, 2020 at 9:01 PM
    jimmy johnny
    1998 Tacoma
    Comparing the two engines side-by-side
  14. Jan 23, 2020 at 8:09 PM
    jimmy johnny
    1998 Tacoma
    Time to mate the 4l60E to the 5.3. I went with a stock torque converter, shown here installed on the transmission.
    And mated up, the engine stand worked nicely and allowed me to use the crane to guide the transmission into place.
    Before bolting the torque converter to the flywheel, you need to make sure there is a small gap (1/16" to 1/8") between the two. This verifies the torque converter is seated properly in the transmission. Pump rotors get broken when the converter is not installed all the way.
    Biscuits and six5crèéd like this.
  15. Jan 23, 2020 at 8:14 PM
    #35
    20tacoma17
    2017 DCLB Sport AT
    I've done that before.
  16. Jan 23, 2020 at 8:28 PM
    #36
    jimmy johnny
    1998 Tacoma
    For the first test fit, I left the front diff in place to see how much room I would have to work with if I wanted to try and get 4WD back in the future. The truck oil pan really sticks down far and the first fit was a fail, I couldn't get the engine over that front rail.
    So I took the oil pan off and tried again.
    The bellhousing was hitting here and would likely need some shaving to make it work. A shallow oil pan might fit but it would be tight. The engine needed to come down a little more in order for the alternator to clear the hood. A body lift would make it a lot easier.
  17. Jan 23, 2020 at 8:35 PM
    #37
    jimmy johnny
    1998 Tacoma
    So I went ahead and removed the diff from the top.
    Engine bay without diff
  18. Jan 24, 2020 at 3:24 PM
    #38
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Subbed!
  19. Jan 24, 2020 at 8:02 PM
    #39
    jimmy johnny
    1998 Tacoma
    Exhaust removal was next.
  20. Jan 24, 2020 at 8:13 PM
    #40
    jimmy johnny
    1998 Tacoma
    For engine mounts, I went with these from LSXinnovations: https://www.lsxinnovations.com/product/ls-swap-motor-mounts-adjustable-universal-steel/
    Now I just needed to figure out what length to cut the two tabs and how to mount them to the stock tacoma engine mounts.
    A few places on the tunnel needed a small amount of massaging to make some room for the back of the heads and a few bump outs on top of the transmission, but it wasn't bad at all.
