1998 tacoma p/u won't start after getting hot
Discussion in 'Toyota Trucks & SUVs' started by Gunboat, Sep 23, 2013.
  1. Sep 23, 2013 at 9:05 AM
    Gunboat
    Gunboat [OP] New Member
    mickey
    usa
    tacoma
    My friend has a 98 tacoms p/c 16 valve,4 cylinder 4 wheel drive.After driving it and it gets to operating temp,and he turns it off,it refuses to start back up until it cools back down...then it starts and runs fine...anyone have any suggestions on what to look for? Also,plugged in the reader to the OBD and it said that the engine was running lean,no other trouble codes came out...the engine cranks over just fine it's getting fire and fuel,new plugs..
  2. Oct 9, 2013 at 7:56 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    Plenty of suspects to check out.
    O2 sensors
    temp sensors
    fuel pressure reg
  3. Oct 10, 2013 at 4:16 AM
    Gunboat
    mickey
    usa
    tacoma
    thanks for the reply...I have read numerous posts on this and they say just about the same thing that you have mentioned,thanks again for the reply..
  4. Oct 31, 2013 at 1:45 PM
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Landry
    North Carolina :/
    2015 TRD Pro Inferno 6spd SUPERCHARGED! DCSB
    Wheelers 3/4 isolator, TRD Supercharger, Weathertech window visor, weathertech digital floor liners, Rigid 30 E series, rear spring mess. Awesome seat covers.
    fuel delivery issue, like mentioned above
    or possibly only enough fuel to run while still on cold start injector? if there was crud in the fuel system the filter does not always get it and it can still plug up your injector's
  5. Oct 31, 2013 at 4:27 PM
    3RZ Taco
    3RZ Taco Well-Known Member
    Austin
    Oregon
    96 3RZ Stock
    K&N air filter, Toolbox, Window Deflectors, Bug Deflector, BFGoodrich A/T's
    Try replacing the fuel cap, my 96 would run fine all day until night time and wouldnt not start unless i fulled the cap off and let the air pressure out of the tank. Searched and searched for what could be the problem, spent 15$ on a new locking gas cap and havnt had the problem since.
  6. Oct 31, 2013 at 6:35 PM
    92yotapu
    92yotapu Well-Known Member
    Joseph
    Ontario
    92 toyota pickup 4x4
    32in tires, blacked out rims grill and door handles
    For your issue check the vent solenoid on your evap canister it night be plugged
  7. Oct 31, 2013 at 6:41 PM
    92yotapu
    Joseph
    Ontario
    Check fuel pressure at cold start and while running warm shouldn't be a major difference and while its running hot pull fuel cap if it hisses like is sucking in air you have a bad tank vent
