1998 tacoma regular cab supercharged ARB lockers 7000
Discussion in '1st Gen Tacomas For Sale (1995-2004)' started by 98tacoma3rz, Apr 16, 2017.
  1. Apr 16, 2017 at 12:45 PM
    98tacoma3rz
    98tacoma3rz [OP] Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    98 regular cab 4x4 manual trans
    I'm the 2nd owner. 1st owner literally had serviced every 5000 miles at Toyota dealer. I have the original window sticker. Excellent mechanical condition. Meticulously maintained.
    2.7 230k miles original drivetrain.
    Trd supercharged just installed 2500 miles ago. Walbro 190 fuel pump and larger flow injectors with URD 2.5 inch pulley. Running around 6 psi.
    Everything below has less than 30k miles
    Northwest off-road header
    Dynomax cat back exhaust.
    Dynomax stainless cat.
    Front and rear ARB lockers. With 4.88 Nitro gears setup by just differentials.
    Front icon extended travel coilovers with spc control arms. Front diff drop. Extended inner poly cv boots, re greased.
    Rear suspension old man emu Dakar with add a leaf, ome shocks, allpro u bolt flip kit, wheelers off-road super bumps, ome greasable shackles.
    Axle relocation plates
    33x10.5 AT2 tires in excellent condition on OEM Toyota steelies.
    Front trail gear bumper with welded small stinger, superwinch 8500 winch.
    Rear trail gear bumper modified with swing out tire and fuel carrier.
    Rear frame boxed. (trail gear kit)
    4x innovations sliders-welded
    Rat products 1/8" skid plate.
    ARB snorkel
    Interior is in excellent shape. Gauge pod installed with aftermarket tech. Comes with cb radio.
    New radiator, recent tune up, upper and lower ball joints, tie rod ends all oem . New head gasket and valves checked by Toyota dealer at 200k miles. New koyo rear wheel bearings and seals.
    Oil changed every 5000 with synthetic blend. Diffs and trans changed at recommended intervals.
    Body has small dings and scratches. Rear fender has started to bubble rust. Front transfer case seal is leaking very slow. Have the seal just haven't had time to replace.
    I'm sure I'm forgetting stuff. This truck runs great. Just drove it up to Maine from Pennsylvania with zero issues.
    Does not come with hilift jack.
    $7000
    xcmtb83 and rj95lss like this.
  2. Apr 19, 2017 at 9:22 AM
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    Probably shouldn't put this here, but we've got the same motor with roughly the same amount of miles. I was wondering... how does the motor do with the supercharger? Does it feel like you would expect it to?
  3. Apr 19, 2017 at 9:24 AM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    Honestly I was a little disappointed. I think the high boost kit makes a big difference but I didn't want to mess with the fuel or timing. It definitely helps though.
  4. Apr 19, 2017 at 9:25 AM
    jgill21
    Jake
    Nashville
    Ah, I see. Does it run as stable and smooth as it did before?
  5. Apr 19, 2017 at 9:27 AM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    Yes, I think it runs better if anything.
  6. Apr 19, 2017 at 9:28 AM
    jgill21
    Jake
    Nashville
    Good to know, thanks! Really clean truck by the way:thumbsup:
  7. Apr 25, 2017 at 11:47 AM
    BartMaster1234
    BartMaster1234 American Auto Horns
    Tyler
    San Francisco, California
    Flux Capacitor
    Where did you get the 2.7l TRD supercharger? I've never seen a Tacoma 4 cyl Toyota supercharger before. Only ever on the 3.4l's.
  8. Apr 25, 2017 at 1:41 PM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    LC engineering has them. Alpine made them originally for Toyota. Magneson males them now I think.
  9. Apr 25, 2017 at 9:59 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I've seen the aftermarket ones, but I've never seen a Toyota distributed OEM TRD one before. Huh. GLWS!
  10. Apr 29, 2017 at 8:16 PM
    rj95lss
    rj95lss Well-Known Member
    Robert
    Pinelands, NJ
    '92 HZJ73 - 1HZ diesel RHD
    SOA with OME, Lockers, 37's, ARB
    Great setup. Do you have more pictures?
  11. May 2, 2017 at 1:31 AM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    Sure do. Pm me your email. Much easier for me.
    rj95lss[QUOTED] likes this.
  12. May 22, 2017 at 7:48 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Ooooo, a supercharged 2.7 :spy:
  13. Jul 28, 2017 at 11:17 AM
    tan-ishman
    tan-ishman Well-Known Member
    San Diego,CA
    2005 DCSB
    a bunch of new/used parts....and some skids.
    Moar pics?
  14. Aug 1, 2017 at 2:50 AM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    New price!
  15. Aug 1, 2017 at 9:47 AM
    jgill21
    Jake
    Nashville
    If I had the cash, it would be in my driveway
    98tacoma3rz[OP] likes this.
  16. Oct 13, 2017 at 2:36 AM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    New price!
  17. Oct 13, 2017 at 11:07 AM
    smmarine
    Melbourne FL
    How do you think the NWOR header helped your low end? I know it was shown as the best for low end torque on the dyno. You feel it in the butt dyno?
  18. Oct 13, 2017 at 11:15 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    If you're willing to part with the supercharger let me know. I can include my stock system.
  19. Oct 14, 2017 at 2:40 AM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    I could definitely notice a difference but I can't compare to other headers.
    smmarine[QUOTED] likes this.
  20. Dec 30, 2017 at 1:22 PM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    Still for sale!
