1998 Toyota Recall Frame Rust Buy Back Offer! 2012
Discussion in '1st Gen. Tacomas (1995-2004)' started by Messyt, Jan 4, 2012.
  1. Jan 5, 2012 at 6:56 PM
    #41
    blitzburgh99
    blitzburgh99 Well-Known Member
    Houston, TX
    1999 Tacoma TRD 4x4
    239,600 (as of 7-20-13 and counting)original owner miles
    If the difference on what you could buy a used clean one and the buyback amount is large enough, you may be able to find a shop to do the work and still be a ahead a little.
  2. Jan 5, 2012 at 9:07 PM
    #42
    LarrysWorld
    LarrysWorld 05 Taquito
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    2in front lift HIDs 15" Steelies
    How much you think Toyota will give me for my 98 PreRunner with 396,000 miles? Haha.
  3. Jan 5, 2012 at 9:14 PM
    #43
    nobody4343
    nobody4343 Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
    Any update on an offet
  4. Jan 5, 2012 at 9:54 PM
    #44
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    llamas98taco, Toyota uses 150% of Kelly Blue Book resale(not trade in) values. If your truck has a KBB resale of $4000, they pay you $6000.
  5. Jan 6, 2012 at 12:12 AM
    #45
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    wolftree, how do I go about trying this deal?
  6. Jan 6, 2012 at 5:57 AM
    #46
    wolftree
    Rick
    Ohio
    llamas98taco,
    First, inspect your frame yourself. Do you see any through hole rust areas or any other areas that look like a potential failure point? Look around the spring hangers in particular. If you find a area in question, schedule a frame inspection at a Toyota dealer, no charge.
    If your truck fails the inspection, Toyota, not the dealer, will begin the process. Toyota will use the K.B.B value and offer you a settlement. Toyota will then buy the truck from you. You are not required to buy a new Toyota or any other vehicle. That will be your decision alone. This is Toyota standing behind their product.
    See my other post on this thread.
  7. Jan 6, 2012 at 11:45 AM
    #47
    Messyt
    Messyt [OP] Well-Known Member
    I still need to fax them my title before they can move on to the offer. I'm walking on egg shells with this. I don't want to get the crusher ball rolling too much before i weigh all of my options. I'm going to look into the frame swap solution and see if i can financially do it and if it won't consume me and result in failure. I do like what blitzburgh99 is saying. Thanks for getting my gears spinning! I wish i researched this thoroughly last year when my frame passed :(. Then i could have prepared my frame, had it pass, Toyota would have put the coating on, i would have my baby for at least 5 more years, then if it failed within that 5 yrs, i would utilize the buy back if need be! I even asked Toyota to wipe my frame inspection from their file! Said, can we just make like this didn't happen and i'll see you next year? No can do!
  8. Jan 6, 2012 at 12:03 PM
    #48
    98tacoma27
    Ben
    Not Beech Creek
    Good luck finding one.
  9. Jan 6, 2012 at 7:47 PM
    #49
    blitzburgh99
    Houston, TX
    1999 Tacoma TRD 4x4
    I just found a prerunner in my area listed for 4995. I sent them a message feeling out an offer of 4000. It has 221,000 miles. I need to go look at the frame and check carfax to see history and make sure it has spent its life in Texas.
    Messyt..keep us posted
  10. Jan 6, 2012 at 8:06 PM
    #50
    50180
    50180 Well-Known Member
    Duluth, MN
    03 TRD DC 4x4
    Deck plate, grey-wire, blue plug, alarm mod, clear corners, moved/painted badges, color matched grill, topper, 5100s, wheelers 5 leaf + 1.5 aal , OME coils, All-Pro rear bumper, Methods w/ 32's, converted HID Hellas, supercharger
    If your truck fails do you have the choice of keeping your truck or do you have to give it up?
  11. Jan 6, 2012 at 8:35 PM
    #51
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    you have to give it up, right on the spot in most cases.
  12. Jan 6, 2012 at 8:37 PM
    #52
    50180
    Duluth, MN
    03 TRD DC 4x4
    OK, guess I don't have it checked then.
  13. Jan 6, 2012 at 8:41 PM
    #53
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Thats what I've heard. You could call the dealer just to make sure.
  14. Jan 7, 2012 at 5:03 AM
    #54
    wolftree
    Rick
    Ohio
    Pol500,
    Unless your truck is totally unsafe to drive after an inspection, no you do not have to give it up right then. It is your truck, no one can tell you what you have to do with it. If the frame is ready to collapse right then, you might have to sign a waiver at worst.
    This is still America, no matter what the politicians think.
  15. Jan 8, 2012 at 12:44 PM
    #55
    CrushEm
    CrushEm Member
    Totally wrong!
    ^^^ Pretty much correct.
    You would probably be asked to sign a waiver of acknowledgement, but even that you can refuse to do. Just get in and drive away.
    *Note... The buyback offer is a onetime offer and one you will never have matched anywhere else. IMO it would be quite foolish to refuse it.
    For example: If your truck was totaled in an accident or stolen... an insurance settlement would never come close to the same $$.
  16. Jan 8, 2012 at 2:35 PM
    #56
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    This guy is being way too emotional about a truck. He's not following any sound logic. I do hope that he follows your advice, for he's own sake.
  17. Jan 8, 2012 at 2:39 PM
    #57
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    if i were you id be looking for a frame or asking toyota how much a new frame would be before i just gave my truck up
  18. Jan 8, 2012 at 3:29 PM
    #58
    TawcoTime
    TawcoTime Taco Verde
    PA
    '01 XtraCab TRD, Manual 3.4
    They no longer make a frame for the 95.5 - 2000 Tacomas.
    That's why there's the buyback offer vs the frame replacement for the 2001 - 2004 Tacomas.
  19. Jan 8, 2012 at 6:22 PM
    #59
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    i know that buy why wouldn't a 01- 04 frame work for a 98?
  20. Jan 8, 2012 at 10:29 PM
    #60
    Messyt
    It's not being too emotional about a truck! I want to keep the truck but definitely keep it safe too! I just want to weigh out my odds 1st before i give up a classic 1998 Limited edition Tacoma. They are super rare, go ahead try to find one. I bet since the buy back, i have one of the last 98 limited tacomas on the east coast or in the country. I'm not a hardcore offroad truckin dude, I have a 86 Banshee for that, trust me now that's my unsafe vehicle! Anyway, i didn't modify the truck, it's all original with the exception of a new toyota Catalytic converter(scumbag thiefs!). I am looking around for a new frame or a cheap taco to swap frames, however, it's quite possible i may take the buy back if i can coordinate a logical solution. If i were to sell this truck to one of you guys, how much would you offer me?
    Thanks once again for helping me with this descision.
    I faxed my title and registration to Toyota. I will post back as soon as i get an offer then we can go from there.
    One more thing, i found a 2001 taco but it's a manual trans and i heard that the manual trans for 2nd gens have issues. What do you think about the 2001 in comparison? Thanks!
