1999 4 cylinder tacoma with 195k, what maintenance does it need?
Discussion in '1st Gen. Tacomas (1995-2004)' started by R.etheridge, Mar 13, 2013.
  1. Mar 13, 2013 at 3:52 PM
    RGosen
    RGosen Well-Known Member
    Christ would now agree, don't get yourself nailed to a tree
    Kamloops B,C CANADA
    2000 toyota tacoma 4x4 2.7
    Cold air intake
    It was not a hard driven truck I really didnt expect damn near everything to be wrong with it. There is no rust or dents or any undercarage damage of any kind and was not a off road beater so I expected things to be in good shape still.
  2. Mar 13, 2013 at 4:03 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Is that approx 150K Miles?
    Thats GREAT!
  3. Mar 13, 2013 at 4:44 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Pull the valve cover and check valve lash thats the only way to know.
    negative ghostrider, doesnt have one of those.
    Maybe on the 22r that was a common issue, not so much with the 2/3RZ, just check it and once the tensioner is fully open, its replacement time
    Not a bad idea to have a once over to get a clue about chassis and other stuff, but I would do the tune up regardless, its not expensive and use denso or NGK plugs ONLY!
  4. Mar 13, 2013 at 6:23 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    You'll have to pull the valve cover (and replace its gasket while you're there!) and check the valve lash.
    I can't remember the specs off the top of my head, but there will be a sticker on the underside of your good with the specs.
    Also, my last comment wasn't even for you. It was for everyone else screaming "distributor cap and rotor" when you clearly stated you had a 99.
  5. Mar 13, 2013 at 6:26 PM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    A good carb clean always works wonders
    :poking:
  6. Mar 13, 2013 at 6:37 PM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    You forgot to tell him about the muffler bearing! :brianr:
  7. Mar 13, 2013 at 6:42 PM
    SpeedoJosh
    Florida
    Muffler?? Since when did steam engines get mufflers?
  8. Mar 13, 2013 at 11:41 PM
    RGosen
    Kamloops B,C CANADA
    Cold air intake
    its actually at 162000 miles:eek:
  9. Mar 13, 2013 at 11:46 PM
    RGosen
    Kamloops B,C CANADA
    Cold air intake
    Thanks for the info. I will have to take it to a shop to check the valves as I have no valve tool to do it and not sure how to in the firts place. I guess I will do the tune up as you say. I did blow some seafoem thru the bb vaccum line if that counts lol what do you suggest for tune up on the 2.7 besides filter and plugs and wires and oils ? I cant find how to clean the idle air control valve or the TPS sensor anywhere..I want them both tomorrow as they are free to clean as I have carb cleaner which woulod work to clean them I hope lol
  10. Mar 14, 2013 at 5:06 AM
    R.etheridge
    R.etheridge [OP] Well-Known Member
    Middle GA
    03 Tacoma TRD 4x4
    DON'T CLEAN SENSORS WITH CARB CLEANER!!!! It will ruin your sensors. There is a spray in a red can its made specifically for TPS, MAF, an other sensitive sensors. Can't remember the manufacturer of it but its in a red aerosol can can called maf cleaner I think. You can get it at any parts store and maybe at Walmart.
  11. Mar 14, 2013 at 6:02 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    CRC makes a MAF cleaner (silver can) and a regular sensitive electronics contact cleaner (red can). Both work fine for cleaning sensors like the MAF.
  12. Mar 17, 2013 at 11:15 PM
    RGosen
    Kamloops B,C CANADA
    Cold air intake
    Hmm I will use my MAF cleaner to clean the IAC then if I deside I have the day to spend doing it. I just dont know if its the problem but I guess no way to tell unless I just clean it. and as for the valves adjustment I am not sure when I can get that done. Just hope it does not ruin my motor if they are not set right. I have no idea if its ever been done and its got 163,000 miles on it
