1999 PreRunner Coolant around intake valve above cylinder #3
Discussion in '1st Gen. Tacomas (1995-2004)' started by de1905, Apr 10, 2010.
  1. Apr 10, 2010 at 9:39 PM
    de1905
    de1905 [OP] New Member
    So I decided to take a part my air intake plenum and give it a good cleaning... Noticed when I did that there was a good amount of engine oil coating all six intakes as well as around all the valves. There is also a small amount of coolant noticeable around one of the intake valves in the #3 cylinder...
    What do you guys think? Blown head gasket? I'm not getting the typical overheating or milkshake oil but I realize that's not always the symptoms of a blown head gasket. I just recently replaced the valve cover gasket on the same side of the engine as cylinder #3 due to a leak.
    Any thoughts would be helpful, thanks guys!
  2. Apr 11, 2010 at 8:58 AM
    de1905
    Still can't find any way coolant could have gotten into the head (around cylinder #3) except by head gasket (or cracked block). Anybody else have any experience with this or something similar?
