1999 toyota tacoma no crack no start problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Offroadkid2580, Jul 14, 2021.
  1. Jul 15, 2021 at 5:55 PM
    Offroadkid2580
    Offroadkid2580 [OP] Member
    Rony
    1999 toyota tacoma prerunner v6
    Is 14v when the car is running? I test the main power cable that goes to the starter it had the same voltage as the battery meaning there is no lost of power from the battery to starter.
  2. Jul 15, 2021 at 6:06 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    That's no indication of the batteries ability under load. If the cranking amps drops when load is applied the voltage drops exponentially.
    Load test the battery at parts store.
    Nessal likes this.
  3. Jul 15, 2021 at 6:09 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yes 14v would be engine running, static voltage should be around 12.6v.
    If the engine cranks normal when you bypass the starter relay that tells me your battery, main power to the starter and engine block ground are good.
  4. Jul 15, 2021 at 6:20 PM
    Black DOG Lila
    Virginia
    With key in ON the cluster lights should be on including the CEL.
    If CEL bulb is burned out the dash cluster has to be removed to replace the bulb.
    The ECM is behind passenger side kick panel so if you have a water leak it gets damaged and connection corrodes and the CEL light if good won't light.
  5. Jul 15, 2021 at 6:50 PM
    Offroadkid2580
    Rony
    It most like is the ECM then the CEL light does turn on and the obd2 port doesn't work
  6. Jul 15, 2021 at 7:40 PM
    Black DOG Lila
    Virginia
    May also be the scan tool being used, corroded connection or damaged wires. If the CEL works the ECM is most likely OK.
  7. Jul 15, 2021 at 8:03 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ok here's engine wiring and ECM pinouts. Pin 16 of the DLC should have power at all times whether the PCM is alive or not and pins 4 and 5 should be full time grounds, if any of those are missing find out why and I bet you find your problem.
  8. Jul 15, 2021 at 8:37 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Could be a bad battery even if you read good voltage. Only way to rule out the battery is to get it load tested. It sounds like you have a manual. Have you tried to bump start it?
  9. Jul 26, 2021 at 12:31 PM
    Offroadkid2580
    Rony
    I just got the new ECM and still no luck but pin 16 of the DLC doesn't have power
  10. Jul 26, 2021 at 12:31 PM
    Offroadkid2580
    Rony
    No I haven't tried jump starting it
  11. Jul 26, 2021 at 12:54 PM
    Nessal
    Texas/Bay Area
    No I meant bump start. It's where you have someone push the truck and get up to speed about 5mph and then you drop the clutch while it's in 1st or 2nd gear. The engine should turn over. I did this back in the days when my battery died on my cars or moto.
  12. Jul 26, 2021 at 12:56 PM
    Nessal
    Texas/Bay Area
    Actually nm, I saw that you have crank when you hook up the battery directly to the starter. That should rule out the battery.
  13. Jul 26, 2021 at 1:28 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Your gona have to find where your losing your power then, does the OBD fuse have power on both sides?
  14. Jul 26, 2021 at 4:29 PM
    Offroadkid2580
    Rony
    I believe it is the same one with the cigarette outlet fuse and it isn't blown
  15. Jul 26, 2021 at 4:41 PM
    #35
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    OBD is on it's own fuse according to the power distribution diagram, still have to check for power there even if the fuse isn't blown to know where in the circuit you need to check from there.
  16. Jul 26, 2021 at 5:04 PM
    #36
    Offroadkid2580
    Rony
    I just checked it and it does have power on both side of the fuse
  17. Jul 26, 2021 at 5:12 PM
    #37
    Offroadkid2580
    Rony
    I'll start looking for the violet color cable now to see if it's damaged
