1gen brake swap onto 2nd gen?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UluaHuntah34, Jul 2, 2023.
  1. Jul 2, 2023 at 9:32 PM
    UluaHuntah34
    UluaHuntah34 [OP] Well-Known Member
    2008 Tacoma 6inch Lift, 2 inch body lift, on 37s
    A buddy of mine had his front brakes swapped to a 1gen caliper set, but unfortunately the mechanic he went to has since retired and can’t be found but I was wondering if anyone else had any information on the process? Is it a direct swap out with 1st Gen parts? Or would I have to change some brake lines around also? I guess would have to figure out a way to mount them also?
  2. Jul 2, 2023 at 11:46 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    Wait you want a 1gen Tacoma breaks on a 2nd Gen?
  3. Jul 3, 2023 at 3:25 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I'm guessing to fit 15" wheels.
  4. Jul 3, 2023 at 6:00 PM
    UluaHuntah34
    Yes correct to fit 15” wheels
  5. Jul 3, 2023 at 6:01 PM
    UluaHuntah34
    Yes for 15” wheels
  6. Jul 3, 2023 at 6:30 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Downsizing on brakes with 37" tires is inadvisable. :) But for academic discussion:
    2nd gen rotor shows 67.5 mm height: https://www.rockauto.com/en/moreinfo.php?pk=1279145&cc=1432865&pt=1896&jsn=566
    1st gen rotor shows 70.5 mm height: https://www.rockauto.com/en/moreinfo.php?pk=1279282&cc=1375343&pt=1896&jsn=724
    This means you'll need a 3mm hub spacer between the hub flange and rotor hat to space it out. A 1/8" spacer will probably work. You'll probably have to hunt for a spacer that fits within the ID of the rotor hat, or sand down the diameter of a larger spacer.
  7. Jul 3, 2023 at 9:12 PM
    UluaHuntah34
    Def not running 37s anymore haha, but thank you for the input
  8. Jul 4, 2023 at 8:05 AM
    TXBoss
    TXBoss Well-Known Member
    DFW
    2009 & 2015 TRD Sport
    Are master cylinder bore sizes the same between 1st Gen and 2nd Gen? Not going to be a huge difference in front brake torque... but something to think about as the brakes are a system.
