1GR-FE 2.0” drive pulley on TRD supercharger
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Athlaos, May 12, 2018.
  1. May 24, 2018 at 8:58 AM
    #81
    Athlaos
    Athlaos [OP] Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    So what you guys are saying is its probably a bad idea to put on that 10" crank pulley.
  2. May 24, 2018 at 9:39 AM
    #82
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    T
    True story. I actually thing you're crazy faith your 2.0 at least without meth or fuel to cool the charge but hey, I'm along for the ride!
  3. May 24, 2018 at 11:30 AM
    #83
    ThomasMore66
    Dallas/Fort Worth & Durango
    Oh, I like things that go boom. First engine I wrecked was a 454. Rods came right out of that oil pan and landed on the highway.
  4. May 24, 2018 at 1:00 PM
    #84
    Athlaos
    Leigh
    Edmonton
    Don't scare me now....
  5. May 24, 2018 at 1:00 PM
    #85
    Athlaos
    Leigh
    Edmonton
    You have no idea mang.
  6. May 24, 2018 at 1:21 PM
    #86
    WhiteTacoJerms
    WhiteTacoJerms Well-Known Member
    Jeremy
    Newbury Park, CA
    2015 White Tacoma TRD Off-Road
  7. May 24, 2018 at 2:07 PM
    #87
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Good lord that is a small pulley. @Athlaos remember if you put a larger crank pulley on you are also spinning everything else faster which translates to more parasitic loss. I had a buddy with an e55 amg who put a smaller crank pulley on and it ended up making more power.
  8. May 24, 2018 at 2:08 PM
    #88
    Athlaos
    Leigh
    Edmonton
    Actually I just would upgrade the supercharger crank pulley.
  9. May 24, 2018 at 2:13 PM
    #89
    Athlaos
    Leigh
    Edmonton
    It also occurred to me today that the auto tensioner pulley is right in the way. I'd have to downsize the auto tensioner pulley at the same time. And even then, I would probably max out at a 7" pulley for the crank.
  10. May 24, 2018 at 2:19 PM
    #90
    Roostfactor
    TX panhandle
    Even with a 7" you would be spinning 19250 sc rpm ar 5500 engine rpm!
  11. May 24, 2018 at 2:24 PM
    #91
    Athlaos
    Leigh
    Edmonton
    Well when you put it that way. That sounds awesome.
  12. May 24, 2018 at 2:31 PM
    #92
    Athlaos
    Leigh
    Edmonton
    I think you could be SOL on that. I just bought a really loud exhaust.
    Trental[QUOTED] likes this.
  13. May 24, 2018 at 2:41 PM
    #93
    Roostfactor
    TX panhandle
    That would be awesome! I also think it gets annoying after awhile.
    Trental[QUOTED] and Athlaos[OP] like this.
  14. May 24, 2018 at 2:43 PM
    #94
    Athlaos
    Leigh
    Edmonton
    To each his own I guess. I love it.
  15. May 24, 2018 at 7:13 PM
    #95
    Athlaos
    Leigh
    Edmonton
    Video plans got derailed by rain here. Sorry guys. Will let you know as soon as they're up.
  16. May 24, 2018 at 7:17 PM
    #96
    Athlaos
    Leigh
    Edmonton
    Can you comment on how much gains could be seen with this on a relatively high-boost TRD Supercharger setup? Even if you're just waving your thumb about it?
  17. May 24, 2018 at 8:25 PM
    #97
    Roostfactor
    TX panhandle
    I wasnt just guessing. My boost has dropped 1.5psi. I have gained about 20hp. No seat o the pants loss in low end.
    I do have full headers, and exhaust though.
  18. May 24, 2018 at 9:48 PM
    #98
    Athlaos
    Leigh
    Edmonton
    That is pretty amazing.
  19. May 24, 2018 at 10:41 PM
    #99
    Roostfactor
    TX panhandle
    As I'm sure you know, boost doesnt make horsepower, flow does.
  20. May 24, 2018 at 10:46 PM
    #100
    Athlaos
    Leigh
    Edmonton
    Yes. In my car club, some f***boys run their turbochargers to 26psi and make 550whp... then the guy who did it right comes along, making 950whp at 29psi.
