1GR-FE 2.0” drive pulley on TRD supercharger
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Athlaos, May 12, 2018.
  1. Jun 7, 2018 at 9:01 AM
    #101
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    This is an interesting thread to say the least. About time someone pushes the envelope. There are a few people who pushed close to 20,000 rpms on the first gen TRD blowers. Lots of water/meth to cool it down. Who knows from the mustang community... Someone should dyno 2.5 and less on the quick change pulley and get real data
    Curious why nobody starts threads in the performance and tuning anymore?
  2. Jun 7, 2018 at 9:15 AM
    #102
    Athlaos
    Athlaos [OP] Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I like your awd X-runner there.
    I am using a fair amount of meth right now, I have 375ml/min at the moment and will be going to 475 this morning as a matter of fact; then I will be adding a second stage that will kick in at higher RPMs, adding an additional 175ml/min. Apparently 375ml/min is for 500whp, so maybe that's what I'm making now? Lol.
    I also have an intercooler capacity upgrade and the 7th injector. And it doesn't even get that warm here. Good thing water/meth is cheap.
    Not sure why people don't post in performance and tuning. I just posted here because I thought I would reach more people. But, it's a good point that the target audience could be there rather than here.
  3. Jun 7, 2018 at 10:36 AM
    #103
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I may be the only other guy running meth.
  4. Jun 7, 2018 at 12:05 PM
    #104
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm just here for the WTF factor.
  5. Jun 7, 2018 at 2:57 PM
    #105
    Athlaos
    Leigh
    Edmonton
    Interesting. I have to say, I'm a big fan.
  6. Jun 7, 2018 at 2:57 PM
    #106
    Athlaos
    Leigh
    Edmonton
    Me too.
    Roostfactor likes this.
  7. Jun 7, 2018 at 3:07 PM
    #107
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    This is the first time I've seen this thread.
    Hot damn, man. You have steel cajones.
  8. Jun 7, 2018 at 3:14 PM
    #108
    Athlaos
    Leigh
    Edmonton
    I think it's just that I don't care.
  9. Jun 7, 2018 at 3:17 PM
    #109
    Jesse
    Poulsbo
    15' DCSB OR S/C
    No, when you go under 2" I'll say you dont care.
    12TRDTacoma and Athlaos[OP] like this.
  10. Jun 7, 2018 at 3:18 PM
    #110
    Athlaos
    Leigh
    Edmonton
    Yeah that's probably true.
  11. Jun 7, 2018 at 3:20 PM
    #111
    Jesse
    Poulsbo
    15' DCSB OR S/C
    If you have meth questions I'm here.
  12. Jun 7, 2018 at 3:44 PM
    #112
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah but you are tuned plus you are running 7th injector.
    You kind of do care. ;)
    Athlaos[QUOTED][OP] likes this.
  13. Jun 7, 2018 at 3:59 PM
    #113
    ThomasMore66
    Dallas/Fort Worth & Durango
    You were on a sabbatical.
    Athlaos[OP] likes this.
  14. Jun 7, 2018 at 4:02 PM
    #114
    Athlaos
    Leigh
    Edmonton
    Well, since you offered, I just increased injection from 375ml/min to 475ml/min. I haven't noticed any issues, it's just an on-off system. I'm going to install a second stage that kicks in at high rpm. I haven't noticed a detriment at low rpm/partially closed throttle.... but how much do you think would be too much, especially at low rpm?
  15. Jun 7, 2018 at 4:04 PM
    #115
    Athlaos
    Leigh
    Edmonton
    Yeah. You got me.
  16. Jun 7, 2018 at 4:44 PM
    #116
    Jesse
    Poulsbo
    15' DCSB OR S/C
    When you feel the motor bogging I'd say. It should come on about 2500rpm. Snow performance has a dual stage controller. That's what I use. I think you could really benefit from it. Dials to turn up or down at will.
  17. Jun 7, 2018 at 4:49 PM
    #117
    Athlaos
    Leigh
    Edmonton
    That's the system I just bought actually. Plan was to install it as the 'second stage' to come on at 3000rpm or so, supplementing the on/off system. Just waiting for my 2nd nozzle kit to arrive now.
  18. Jun 7, 2018 at 4:52 PM
    #118
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I see. It's a dual stage. So you'll have three tiers of meth. Wow!
  19. Jun 7, 2018 at 4:58 PM
    #119
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Are you running 50/50?
  20. Jun 7, 2018 at 5:05 PM
    #120
    Athlaos
    Leigh
    Edmonton
    Yep.
