1GR-FE 2.0” drive pulley on TRD supercharger
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Athlaos, May 12, 2018.
  1. Jun 15, 2018 at 7:33 AM
    #141
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Its purpose is cooling and octane boost. Octane for being safe for knocking, cooling for additional stress of aggressive tuning. I'm happy with my kit from snow performance.
    Murphinator likes this.
  2. Jun 15, 2018 at 8:53 AM
    #142
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    whats activated the meth to turn on? and its a progressive system?
  3. Jun 15, 2018 at 9:16 AM
    #143
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    There are many different meth setups you can get. There are basic ones which are kind of like an on off switch. Then there are progressive systems and there is two activation methods I know of. One is by splicing into the MAF sensor’s wiring, the other is by using a MAP sensor. Lightning is using the maf sensor which I think I am going to pull the trigger on as well, probably will buy the maf extension harness URD sells so I do not have to splice into factory wiring.
  4. Jun 15, 2018 at 9:40 AM
    #144
    Jesse
    Poulsbo
    15' DCSB OR S/C
    It is progressive as well.
  5. Jun 15, 2018 at 9:41 AM
    #145
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Is there a Meth BS thread already? Seems like a really ideal thing to run and I would love to see some write ups pics and advice. But I also don't mean to hijack this thread.
  6. Jun 15, 2018 at 10:01 AM
    #146
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I thought about writing up my limited knowledge and experience.
  7. Jun 15, 2018 at 10:12 AM
    #147
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Do it. We shall share our knowledge and hopefully more people will start discussing/using it!
  8. Jun 15, 2018 at 10:13 AM
    #148
    Athlaos
    Athlaos [OP] Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I have one right now that triggers at 6psi. I am going to add a second pump that triggers at about 4000rpm. Just waiting for the new nozzle now.
  9. Jun 15, 2018 at 10:14 AM
    #149
    Athlaos
    Leigh
    Edmonton
  10. Jun 15, 2018 at 10:33 AM
    #150
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    That would be awesome! Just start a bs thread and everyone will trickle in
  11. Jun 15, 2018 at 10:40 AM
    #151
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Ok. When I'm off work today I will.
  12. Jun 15, 2018 at 10:40 AM
    #152
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
  13. Jun 15, 2018 at 2:41 PM
    #153
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I posted a meth thread in technical chat if y'all want a good laugh.
    Biscuits and Athlaos[OP] like this.
  14. Sep 4, 2018 at 1:15 PM
    #154
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    Wow that exhaust is loud!
    (non SC question) did you upgraded your clutch/flywheel?
    **Edit, just looked on your build page...yes...yes you did upgrade
    Athlaos[QUOTED][OP] likes this.
  15. Sep 4, 2018 at 1:17 PM
    #155
    Athlaos
    Leigh
    Edmonton
    Ya, I am buying a Synapse resonator that should help it quiet down, especially for highway driving.
  16. Sep 27, 2018 at 12:17 PM
    #156
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Holy crap, you did work on that snout.. :sawzall:
