1GR-FE ALUMINUM INTAKE MANIFOLDS
Discussion in 'Performance and Tuning' started by TRfknD, Sep 15, 2012.
  1. Oct 18, 2012 at 11:32 AM
    #81
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  2. Oct 18, 2012 at 12:06 PM
    #82
    TRfknD
    TRfknD [OP] Active Member
    The Woodlands, TX / 671
    96 Turbo Taco
    BOOSTED @ 17PSI 415hp / 345tq
    Cool bro! I would love to see your 1GR-FE run on the 1/4 mile. Gabe is already discussing how we can hit the 500hp mark! lol
    Can't wait to see yours run!
  3. Oct 18, 2012 at 12:20 PM
    #83
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    On your engine, 500 is nothing for it. ;) What kind and size turbo are you running?
  4. Oct 18, 2012 at 12:25 PM
    #84
    TRfknD
    96 Turbo Taco
    Running the Garrett 60-1 t3/t4 w/ a/r .63
  5. Oct 18, 2012 at 1:06 PM
    #85
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Can't wait for the intake manifold on my truck! With numbers like that in a truck that small it must move along real nice.
  6. Oct 18, 2012 at 1:29 PM
    #86
    TRfknD
    96 Turbo Taco
    It moves a bit quicker...lol;)
  7. Oct 18, 2012 at 1:36 PM
    #87
    Lucario Runner
    Robert
    06 Toyota 4Runner
    You should run that thing around MSR. :D
  8. Oct 19, 2012 at 5:49 AM
    #88
    The Phoenix
    The Phoenix Member
    Rocky
    Tonka
    I don't believe that that would be a very wise approach for gaining power. I bet you $10 that the parts on the 03-04 will be identical to the parts on a 2011 (maybe not a 2012 since they added some pollution control parts).
    And the higher power rating carried right into 2005. If you look at the 2005 Tacoma specifications, they were rated 164 and 245 hp. They are now (starting with 2006) rated 159 and 236 hp. The difference isn't in the engines, its in the calculations, "SAE certified power" came into effect.
  9. Oct 19, 2012 at 6:36 AM
    #89
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It might be possible about the SAE time frame. I am not sure. I just remember reading that the 03-04 had higher torque and HP than the -05+, on the same octane levels.
    There is one significant difference between those two versions of the 1GR. The intake cam gears have different pick-up's for the intake cam gear sensors. Which are also different, and cannot be used between the 4Runner and Tacoma. The intake cam gears of the different versions are however, interchangeable. As I have swapped cam them. It is also necessary if you install an 03-04 1GR into an 05-11.
    Currently, I am rebuilding the 03 1GR, and am going to put a good clean set of 05+ heads onto it. I know they will bolt up already, which complements what you stated. There might however, be a difference in the cam profiles, which makes for slightly different power levels? At this point, i don't even give a damn about that though, asong as I can get this engine (my back-up) running again. Lol.
    03-04 also have pistons made by "ART", whereas the 05+ are made by Aisin.
  10. Oct 19, 2012 at 11:18 AM
    #90
    toon714
    toon714 Well-Known Member
    toon
    So. Cali to H-town
    2010 turbo lowered prerunner
    garret Gt 35R front mount turbo, TR lowering kit, Work wheels, all the go fast goodies!
    still waiting on my intake manifold....
    hopefully itll be done soon.
  11. Feb 8, 2013 at 5:50 AM
    #91
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    How much are these? I tried to get in contact with gabe no luck
  12. Mar 2, 2013 at 8:53 PM
    #92
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Some eye candy aredeges_ba47d89aa33c0fd1ba90cf6d14fe6ecda0f2c868.jpgusede2u4_146d6f99e035bad342cd911f6f3d8b705e4067b0.jpg
    Bedbull and xaqori like this.
  13. Mar 2, 2013 at 9:01 PM
    #93
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    that is indeed some eyecandy!! :eek:
  14. Mar 2, 2013 at 11:53 PM
    #94
    Lucario Runner
    Robert
    06 Toyota 4Runner
  15. Mar 3, 2013 at 5:25 AM
    #95
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Well?!?! What do you think about the intake?
  16. Mar 3, 2013 at 5:43 AM
    #96
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    The runners are too short. Looks neat, buuut, post and pre-dynos would be nice along with any flow bench stats
  17. Mar 3, 2013 at 7:49 AM
    #97
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    It could very well look like this if someone wanted to have is dipped in carbon fiber. On the other hand whatever happened to the dyno numbers and a price on this thing.
  18. Mar 3, 2013 at 7:55 AM
    #98
    MIAtaco
    MIAtaco Well-Known Member
    Brian
    Miami FL
    2010 tacoma base lifted
    2.75" front lift 2.5" rear, pro comp es3000 rear shocks w/ orange shock boots, custom exhaust, k&n cold air intake, 20" led light bar behind grill, aftermarket grill, T-rex3 eyelids, pioneer HD radio
    now we need one for us guys with the 2tr-fe 4 bangers
  19. Mar 3, 2013 at 11:32 AM
    #99
    Kuhl29
    Kuhl29 King of the Goobers
    Brea, CA
    White 07 PrerRunner
    Swayaway stock replacement coils, Bilstein 5100's (rear), Removed Swaybar, Magnaflow Exhaust, 8000k HID Kit, camburg UCAs, camburg spindles, Doug thorley shorties
    :popcorn:
    i'll be keeping my eyes on this thread for those dyno results...( would love to get a little more "oomfph" under the hood).... and for amusing freakouts and arguements. hahahaha.
  20. Mar 3, 2013 at 1:43 PM
    #100
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
