1GR-FE ALUMINUM INTAKE MANIFOLDS
Discussion in 'Performance and Tuning' started by TRfknD, Sep 15, 2012.
  1. Mar 3, 2013 at 2:09 PM
    #101
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    Well having this installed my truck is running lean which means I'm gettin more air an I already have it tuned for the cold air intake so I'm flowing more so even with the current design it's flowing more a little more of a tweak it will b nasty
  2. Mar 3, 2013 at 6:14 PM
    #102
    jprovence
    jprovence Well-Known Member
    Joshua
    Albany
    11' Tacoma TRD
    Stock
    I'm late into this thread. But I'd be interested to see what kind of low end grunt that can be had. I'm not interested in top end power for a truck that will never see 6k rpm.
  3. Mar 3, 2013 at 6:34 PM
    #103
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    curious to see HP n TQ numbers
  4. Mar 3, 2013 at 6:43 PM
    #104
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
  5. Mar 3, 2013 at 6:57 PM
    #105
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
  6. Mar 4, 2013 at 6:50 AM
    #106
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    perhaps, although MAF position in regards to flow boundary layer is more correct, you may have freed up resistance in the tract , however not knowing where the velocities are in relation to amount of air may be a bigger issue.
    I have to say it is unique to attempt to tackle this actually and would love to see some numbers.
  7. Mar 4, 2013 at 7:36 PM
    #107
    Kuhl29
    Kuhl29 King of the Goobers
    Brea, CA
    White 07 PrerRunner
    Swayaway stock replacement coils, Bilstein 5100's (rear), Removed Swaybar, Magnaflow Exhaust, 8000k HID Kit, camburg UCAs, camburg spindles, Doug thorley shorties
    cmaaan, donde esta numeros?! i wanna see this thing in action!!!
  8. Mar 4, 2013 at 7:38 PM
    #108
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Yea seriously. I wantz more brappppp
  9. Mar 4, 2013 at 7:46 PM
    #109
    drade
    drade BRUINS 4 LIFE
    ME
    2016 Toyota Tacoma TRD Off Road Short Cab Silver
    TRD PRO skid plate, wet kole seat covers, tint all around, red line tuning quick Lift system, paint protection film, gloss blacked out OEM emblems, electric start, heated seats.
    ##############'s please
  10. Mar 6, 2013 at 6:05 AM
    #110
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    I would get numbers but my turbo is coming in so it doesn't matter what the before an after is for just the intake lol
  11. Mar 6, 2013 at 6:16 AM
    #111
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well, actually, a dyno with your truck the way it is, while listing all of the additional mods, would still be quite helpful. Since I have coalesced dynos with all sorts of mods. It would be fairly easy to see where this intake on N/A trim stack up. And we would have a relative idea of its gains. :)
  12. Mar 6, 2013 at 6:32 AM
    #112
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    sub'd
  13. Mar 6, 2013 at 11:47 AM
    #113
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Ya I'm just not spending the money twice for a dyno
  14. Mar 6, 2013 at 12:20 PM
    #114
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  15. Mar 6, 2013 at 12:46 PM
    #115
    Kuhl29
    Brea, CA
    White 07 PrerRunner
    i want to know the numbers solely based off of the performance of the manifold. not gettin a turbo any time soon. the turbo could throw off the improvement of the manifold. am i right?
  16. Mar 6, 2013 at 1:23 PM
    #116
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    then ask the dude who built it to pitch in
    I would think he would want some kind of numbers to show people
  17. Mar 6, 2013 at 3:15 PM
    #117
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    No it's not gonna affect it because it will have pressure bein pushed in it. I know the custom intake is better for a turbo setup because it gets in the runners equally rather than the dual runner high/low on the stock intake
  18. Mar 6, 2013 at 6:50 PM
    #118
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Trust me, that was the plan. And still is, but will be a little later than expected. I gave the components to the fabricator to make this and other style intake manifolds for the 1GR. We were going to test it out a while ago. But it was kind of put on the back burner. Eben if Doublld does decide to get a dyno, I still plan on doing before and after dynos myself. N/A and turbo.
  19. Mar 6, 2013 at 10:36 PM
    #119
    tinker_troy
    T R O Y
    WY/SD
    Groovy
  20. Mar 6, 2013 at 10:37 PM
    #120
    skygear
    skygear                    
    Damn, If only I had a shop of my own.
