1GR-FE ALUMINUM INTAKE MANIFOLDS
Discussion in 'Performance and Tuning' started by TRfknD, Sep 15, 2012.
  1. Mar 20, 2013 at 6:22 AM
    #141
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Drop the hammer!
  2. Mar 20, 2013 at 6:27 AM
    #142
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    Y'all are right I apologize just got a little worked up. I was tired of people hating
  3. Mar 20, 2013 at 6:32 AM
    #143
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i think most folks were asking for numbers based off this post...
  4. Mar 20, 2013 at 7:04 AM
    #144
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    I was mainly talkin bout the guy who was sayin this thread seems strangely familiar he bashed on torspd when he was doin the manifold spacers. Anyway I was wrong the way I responded an apologize
  5. Mar 20, 2013 at 10:17 AM
    #145
    xyourlocaldjx
    xyourlocaldjx Well-Known Member
    I like turtles.
  6. Mar 20, 2013 at 10:22 AM
    #146
    Kuhl29
    Kuhl29 King of the Goobers
    Brea, CA
    White 07 PrerRunner
    Swayaway stock replacement coils, Bilstein 5100's (rear), Removed Swaybar, Magnaflow Exhaust, 8000k HID Kit, camburg UCAs, camburg spindles, Doug thorley shorties
    i never bashed anyone. I AGREED that it was getting familiar because I had asked about numbers before.
  7. Mar 20, 2013 at 10:58 AM
    #147
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Didn't say you did. It's all good
  8. Mar 21, 2013 at 6:25 AM
    #148
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well, I do have a bit of good news. My truck is driveable again.....kind of. I have to drop it off at PowerFab to get a few things modded on the frame and welded to the axle. Either way though, it is time to dyno in its N/A form. So if Gabe has a spare manifold available that is NOT the one used for mock-up, then I can test both. I will ask him and see what he says.
    How's that sound?
  9. Mar 21, 2013 at 8:22 AM
    #149
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Tor you're getting me Excited!
  10. Mar 21, 2013 at 8:59 AM
    #150
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Going to get a hold of Gabe and see what we can do. :thumbsup:
  11. Mar 21, 2013 at 9:58 AM
    #151
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    don't forget about me......:(
  12. Mar 21, 2013 at 10:41 AM
    #152
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Apparently your engine sits higher in the engine bay. That is why it didn't fit. I talked with Gabe earlier to confirm that he didn't modify the one on DoubllD's truck. And he didn't. So for the 4Runner, it would need to be a little shorter.
  13. Mar 22, 2013 at 6:54 AM
    #153
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    One thing that I want to mention, and I don't know why I never did before, is this. So I apologize for that.
    To bring things back into perspective. The reason that I went to Gabe to create this manifold in the first place, as well as for its primary function, was to make a strong intake manifold which would handle the constant high boost pressures which I will be running. Not knowing the limits of the factory plastic manifold, and not wanting to find out while driving, that is where this came from.
    Secondary benefits would be added HP and TQ.
    I don't know how I became side tracked and forgot to mention that, but I just wanted to make that clear. I was actually reminded just a littke ago while talking with his close friend, my co-worker. He introduced me to Gabe, and was there when I gave all of the necessary parts to him for mock-up/construction.
    Nevertheless, the dynos will be happening soon. On a model that is very similar to the one which DoubllD has right now. That specific design is for a boosted application. Gabe has a different style which will be for N/A, but has not yet made one.
    A little back story about the manifold that DoubllD has: When Gabe first brought it over to test fit, it was supposed to be test fit on Toon714's truck. Unfortunately though, his truck was being tuned by Chris Delgado from D3. Well Lucario Runner was also at my house since he came down to check it out as well. So we test fit it on his instead. Immediately we noticed that the hood wouldn't close. So Gabe went back and threw one together that to test fitment on Lucario Runner's 4Runner. That was simply a rush and test manifold. Not actually optimized for strength or performance.
    The theory of performance gained was realized when they did a test drive, though. As the AFRs were lean. Which meant much more air. Soon after that, Toon moved to Cali, and my truck still wasn't operable. So we didn't have anyone close to test out the first constructed manifold on. And it was put on the back burner.
    Fast forward to the beginning of March, and DoubllD has it installed on his truck and it fits properly, with out any modification to the height of the manifold. That means that effectively, the 1GR in the 4Runner sits higher than in the PreRunner/4x4.
    Had we had the ability to test fit it on mine or Toon's, these would have progressed much more quickly.
    400 more miles to go to break in my clutch, and as soon as Gabe is finished with the next one, it will be dyno time. :D
  14. Mar 22, 2013 at 8:19 AM
    #154
    toon714
    toon714 Well-Known Member
    toon
    So. Cali to H-town
    2010 turbo lowered prerunner
    garret Gt 35R front mount turbo, TR lowering kit, Work wheels, all the go fast goodies!
    Ya. I hate so cal now
    Because it delayed this manifold from being made.
    I wish i didnt have to move around this time that this was being made....
    But it should be made soon. :)
    And i cant wait!!
    Once its on my truck. It will be dyno with before and after with the turbo.
  15. Mar 22, 2013 at 8:28 AM
    #155
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Good glad 2 hear progress is bein made. I should have my turbo installed and all the other mods that come with that around the end of April
  16. Mar 22, 2013 at 8:31 AM
    #156
    toon714
    toon
    So. Cali to H-town
    Whos building ur turbo setup?
    Front,rear, or mid?
  17. Mar 22, 2013 at 9:32 AM
    #157
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Sts rear mount. I work at a fab/repair shop so we are gonna tweak the system to get everything out of it
  18. Mar 22, 2013 at 10:08 AM
    #158
    Kuhl29
    Brea, CA
    White 07 PrerRunner
    thank you for the update. I appreciate the info as well. good luck with the testing, we are looking forward to it.
  19. Mar 22, 2013 at 1:25 PM
    #159
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sometimes I wonder why this thread isn't in the "Performance and Tuning" section....?
  20. Mar 22, 2013 at 2:42 PM
    #160
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I know a guy that can fix that...
