1GR-FE Billet Anodized Fuel Rails *** TRD SC approved ***
Discussion in 'Performance and Tuning' started by 05Taco4x4, Jun 8, 2019.
  1. Jun 8, 2019 at 10:39 PM
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    A few members complimented my 2TR fuel rail and encouraged me to make 1GR rails but I wasn't excited to do it because my truck wouldn't benefit and there would be development expenses. But then @loginfailed communicated his seriousness and commitment to buy and I guess that's what I needed- it also helped that he already had the parts I needed to measure and develop from haha. Three months later we have verified 3D prints that clear the TRD supercharger and confidence in the design to allow others in.
    If you want in let me know here. Once the target number is reached we'll proceed.
    Driver Side
    Passenger Side
    Supercharger clearance
    Jumper soft line is not included
    7075-T6
    Anodized black
    8-ORB ports (1/2" ID)
  2. Jun 8, 2019 at 10:39 PM
    05Taco4x4
    2TR-FE Enthusiast
    BillDaCat8 and Biscuits like this.
  3. Jun 8, 2019 at 10:40 PM
    05Taco4x4
    2TR-FE Enthusiast
  4. Jun 9, 2019 at 3:04 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Big thanks to @05Taco4x4 for doing all of the legwork on this that I don’t have the skill set for!
    There is about 5.25” of clearance between the end of the passenger side fuel rail and the firewall, so the Radium DMR 20-0223-00 should easily fit there.
    The fuel input will be at the back end of the driver side rail. The pulse damper will go on the side of the driver rail, pointing roughly in line with the PCV nipple on the valve cover.
    To make the crossover tube, the 90* fittings that I found to easily clear everything are these -8an orb swivel fittings from Fassterllc on eBay.
    https://www.ebay.com/itm/X771-8AN-F...re-Aluminum-SWIVEL-Fitting-BLACK/141849263715
    I know of a few guys that have already expressed interest so I’m tagging them as well as guys who might be at least potentially interested or could help spread the word.
    There is a huge price drop if we can get 5 orders and another small drop if we can get to a batch of 10.
    1-4 $946
    5-9 $489
    10+ $404
    @Athlaos
    @White lightning boosted
    @GT7
    @Roostfactor
    @Torspd
    @Biscuits
    @5thGearPinned
    @JustDSM
    @ThomasMore66
    @TRON
    @12TRDTacoma
  5. Jun 9, 2019 at 3:30 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Note for those of us with FIC injectors:
    EDIT: There will be an FIC injector version of these rails to accommodate the additional 3mm length. Thank you @05Taco4x4 !
  6. Jun 9, 2019 at 8:18 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Very very very nice!
  7. Jun 9, 2019 at 11:23 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I wish I was rich!
    Stryker420, Biscuits, Athlaos and 2 others like this.
  8. Jun 9, 2019 at 12:26 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Make the y-pipes faster! LOL
  9. Jun 9, 2019 at 1:12 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Slight thread jack but I see the first post says pricing for 1. Would you be willing to make me a one off set of 2UZ rails?
    I had to adapt 2UZ rails to my 3UZ in order to use the supercharger. But the 2UZ has a return line and my 3UZ is returnless. What I had to do was use the biggest bolt possible and block the return port. Looks stupid.
    Athlaos likes this.
  10. Jun 9, 2019 at 2:22 PM
    Roostfactor
    TX panhandle
    I am just slow and methodical. Besides, there is just no way I could keep up with the "Silent Ninja Wizard"! I even spoke of that exact topic yesterday when fitting @BassAckwards TRD exhaust to my y-pipe.
    You have some speedy skills my friend! More importantly your quality doesnt suffer with said speed.
    BassAckwards likes this.
  11. Jun 9, 2019 at 2:51 PM
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    My only hesitation is the shaving down the ports to make this work.
    Biscuits, loginfailed and GT7 like this.
  12. Jun 9, 2019 at 2:56 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If we can get at least 5 FIC injector guys in, we might be able to convince @05Taco4x4 to make an FIC specific version.
  13. Jun 9, 2019 at 3:02 PM
    05Taco4x4
    2TR-FE Enthusiast
    If you're saying you need returnless 2UZ rails, how about I do 2UZ rails and you use a flush 8-ORB plug on the end.
    I don't mind but you're looking at more than that price because the V8 rails are longer, and loginfailed already had extra parts to ship me to take measurements. I'll PM you.
  14. Jun 9, 2019 at 3:04 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I greatly favor that idea. Make it specific for fic injectors, with slight modifications to make factory trd injectorsto work. If yes, count me in. Let's rally the troops to get 10 guys. We're 1/5th there now.
  15. Jun 9, 2019 at 3:07 PM
    05Taco4x4
    2TR-FE Enthusiast
    I have no problem with this, I imagine most you guys getting at this time will have the FIC anyways.
    I could have 3mm injector port spacers made for those wishing to use stock size injectors, the o-ring is well above that line that it would seal the same. Or if there's at least 5 of each sub-group, enough to capture the reasonable price, then maybe everyone happy to split to two orders.
  16. Jun 9, 2019 at 3:11 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Both solutions I really like. Put me on the list.
  17. Jun 9, 2019 at 3:12 PM
    05Taco4x4
    2TR-FE Enthusiast
    Done
  18. Jun 9, 2019 at 3:12 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Will anodizing be included? Bright red would be my first choice if I have one. If no I'll take whatever finish happens.
  19. Jun 9, 2019 at 3:15 PM
    05Taco4x4
    2TR-FE Enthusiast
    Anodizing included, black standard. I'll request different colors but usually bulk pricing means everything is EXACTLY the same.
    Everyone getting in on this can request a color, but must accept that it may be black.
  20. Jun 9, 2019 at 3:39 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I confirm I'm on the list for this buy.
