1gr-fe cylinder heads
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dcinma, Oct 2, 2024.
  1. Oct 2, 2024 at 11:03 AM
    Dcinma
    Dcinma [OP] Well-Known Member
    Dave
    2011 Access Cab, SR5, 4.0L, 6sp., 4WD.
    4 lo mod. Tinted windows, visors, Roll n Lock tonneau cover, rubber bed Matt.
    If Toyota says you can't mill these heads, how come there are so many reman. heads available online?
  2. Oct 3, 2024 at 2:12 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    They are probably only rebuilding heads that don't need milling, or they're doing it anyway against manufacturer's advice, or they're not checking. Or one of each, depending on how they feel that day.
    These days a LOT of "rebuilt" heads, blocks, even entire engine assemblies are not particularly trustworthy. Sucks. Not just engines - transmissions, racks, anything. Good enough to get it put together and then stall your warranty claim by blaming the install or forcing you to pay shipping back to get another dubious part.
    Dm93 likes this.
  3. Oct 3, 2024 at 2:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Dm93 likes this.
  4. Oct 3, 2024 at 2:45 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    This pretty much sums up the majority of the reman parts business, it could be just barely in spec or even slightly out of spec and they will still ship it along with the cheapest parts/gaskets/materials that will still get the job done.
    The reason Toyota reccomends not to mill the heads/deck the block is because changing the height of the cam gear in relation to the crank gear affects cam timing, not by much but enough that you could end up with timing codes.
  5. Oct 5, 2024 at 5:52 AM
    Dcinma
    Dave
    YES, I recently found out about Cometic and visited their website. Definitely I would talk to a machine shop first.
    I get a few drops of coolant by no. 1 cylinder during a cold start-up and then it stops as the engine warms up. No coolant in the oil.
  6. Oct 5, 2024 at 5:55 AM
    Dcinma
    Dave
    I know it is sad, even brand new suspension parts with lifetime warranties failing early, but they don't reimburse me for my labor.
  7. Oct 5, 2024 at 8:56 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Just curious, how did you diagnose this? Just by seeing localized "steam cleaning" in a certain spot in that cylinder? Or a coolant system pressure test + visual borescope inspection?
  8. Oct 5, 2024 at 4:20 PM
    Dcinma
    Dave
    last March I was rebuilding the front end before getting new tires. Somehow I noticed some crusty pinkish/crust under the manifold. At that point I said to myself don't worry about it yet until I take care of the current problem.
    About two months ago I noticed the "scab" was growing although only slight coolant loss, none on the ground, and none in the oil.
    So I blasted it with hot water cleaning it all away. I discovered upon cold start up it only drips a few drops of coolant while it warms up.
    GilbertOz likes this.
