1GR-FE Dry-Sump Lubrication?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KenLyns, Aug 9, 2010.
  1. Aug 9, 2010 at 8:08 PM
    KenLyns
    KenLyns [OP] 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Noticed these guys installed another fitting between the oil cooler and the oil filter. The fitting has two steel-braided hoses going into it. Does that look like part of a dry-sump system?
  2. Aug 9, 2010 at 8:26 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    I dont know but lets see the numbers for that thing.....i would assume its an x runner
  3. Aug 9, 2010 at 8:28 PM
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Wesley Chapel, FL
    08 PreRunner SR5 TRD Sport
    Stuff and Things
    that might be for a pcv catch can
    edit: correct me if i'm wrong i think that is the engine bay of the prototype trd x-runner
  4. Aug 9, 2010 at 9:21 PM
    JKD
    JKD Well-Known Member
    More likely it is an external oil cooler.
  5. Aug 9, 2010 at 9:21 PM
    KenLyns
    Belly of the Beast
    PCV catch can should not require steel braided lines of that size. Definitely oil lines at highe pressure.
  6. Aug 9, 2010 at 9:45 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    im almost positive your correct...therefore whatever is on there, its just to look cool....
  7. Aug 9, 2010 at 9:47 PM
    JKD
    Wait..duh, oil lines for the supercharger.
  8. Aug 10, 2010 at 10:10 AM
    KenLyns
    Belly of the Beast
    It IS the TRD X-runner, never in doubt. Interesting enough they are using the stock oil filter and oil cap instead of TRD parts. The TRD oil filter is suspected to be the same as K&N, which has less filter area and possibly greater pressure drop.
    So unlike the regular TRD supercharger, which has its own self-contained supply of oil, you think this one uses engine oil?
  9. Aug 10, 2010 at 10:22 AM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    before we all start getting crazy on this...where did you find this pic? is it infact from the SEMA yellow xrunner? cause i know that was all tricked out and supposedly the engine didnt even run...which is why i stated i think a lot of that stuff is for show...
  10. Aug 10, 2010 at 10:59 AM
    JKD
    I don't have a lot of experience with superchargers, I just know that turbochargers require engine oil pressure and perhaps some superchargers do the same. If this is a regular TRD supercharger, and if those have their own oil, then that leaves me with my other hypothesis, external oil cooler.
  11. Aug 10, 2010 at 11:11 AM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    or its just for show....;)
  12. Aug 10, 2010 at 7:46 PM
    KenLyns
    Belly of the Beast
    Like I wrote before, it is the yellow X-runner. The magazine has action shots of the truck, so it ran...
    http://www.modified.com/features/0612_sccp_trd_toyota_tacoma_x_runner/photo_15.html
    Looking at the other pics, the truck has a one-piece grille and bumper cover. Damn, wonder how much that cost to fabricate.
    The stock oil-to-water cooler should be sufficient. Honda sport bikes use a similar oil cooler and those engines rely tremendously on oil for cooling. I think the most appropriate reason for the fitting is connection to a dry-lump system. The stock 1GR-FE oilpan was never designed for the lateral g's this truck is capable of.
