1GR-FE Engine Cover - Why does this cut out exist?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2015WhiteOR, Dec 26, 2021.
  1. Dec 26, 2021 at 12:43 PM
    2015WhiteOR
    2015WhiteOR [OP] Well-Known Member
    Gainesville TX
    You can see from the injection mold that they obviously added more height to that region so it wasn't for clearance purposes.
    And if one were to undo that connector, it would just be easier to undo the 2 acorn nuts holding the cover on in the first place.
  2. Dec 26, 2021 at 4:54 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Good question, maybe just a visual inspection port?
  3. Dec 26, 2021 at 7:27 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Just went and checked under the hood. Same opening on my 2014.
    I did just do my MAF and throttle body... is that the MAF plug? If so, why the port?
  4. Dec 27, 2021 at 7:52 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    That is the MAF connector.
    Just remove the 2 acorn nuts and the cover will pivot at the rear. A firm tug will release the pivot, then the cover can be removed.
    There are no electrical connections on the cover.
  5. Dec 27, 2021 at 8:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Plain and simple. Access port.
