1GR-FE Head Gasket Failing - Options
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chasdw, Jul 29, 2014.
  1. Jul 29, 2014 at 6:57 PM
    chasdw
    chasdw [OP] Member
    Norman OK
    4WD
    I am 99% sure that my Tacoma's head gasket is failing at cylinder 6.
    Same symptoms as most others I have read...
    Rough start in the morning for a few seconds. Clears up and runs fine.
    Code for misfire on cylinder 6
    I have changed all spark plugs. Swapped the coil from cylinder 6 with cylinder 4. Same error and symptons.
    Also, slowly using coolant...
    What I would love from all of you good people is some help sourcing a donor motor, truck or opinions on fixing the current motor.
    2005 Tacoma
    165K miles
    So do I
    1.) Fix the head gasket and replace the water pump
    2.) Find a used low mileage donor motor and do a motor swap
    3.) Find a totaled Truck, swap the motor, use whatever other parts I can and then part it out myself hoping to recoup what I can.
    2 - The question is what is the latest year motor I can swap into my truck.
    3 - What would a good price be for a totaled truck
    Drinking my sorrows away...ha ha
    Thanks in advance for everyone's help/advice.
  2. Jul 29, 2014 at 7:00 PM
    Fordidipower
    Fordidipower Well-Known Member
    Sin city
    2011 4door 4x4 4L auto-sold
    I would crack it open and let the condition of it determine the next step.
  3. Jul 29, 2014 at 7:02 PM
    chasdw
    chasdw [OP] Member
    Norman OK
    4WD
    So the 165K miles would not discourage you from fixing the gasket and buttoning it back up if the inside looked good.
  4. Jul 29, 2014 at 7:03 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    i had one like yours at work and i did the hg and stuff and it was fine
    think it cost the customer like 1500
  5. Jul 29, 2014 at 7:06 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Just do the head gasket properly. Inspect the tops of the pistons and cylinder walls for any abnormal wear. If all that is good then install the head and everything else and go with it. There is no need to replace and engine because it blew or is slowly blowing a head gasket. People have them done all the time.
  6. Jul 29, 2014 at 7:11 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    On a tacoma? U must of come from a long line of gm vehicles. Its a scientifically proven fact that tacomas have/can/will run upto but not limited to 50,000 miles with absolutely no gaskets, seals, or fluids with only minor issues reported. Bottom line is its a toyota, fix it and drive another 200k+ miles one that thing.
    PzTank likes this.
  7. Jul 29, 2014 at 7:16 PM
    chasdw
    chasdw [OP] Member
    Norman OK
    4WD
    You are correct, this was my first Toyota...
    PzTank likes this.
  8. Jul 29, 2014 at 7:16 PM
    chasdw
    chasdw [OP] Member
    Norman OK
    4WD
    Really appreciate all the input...
  9. Jul 29, 2014 at 7:48 PM
    Fordidipower
    Sin city
    With normal wear I wouldn't worry about 165k. Like stated above I would inspect everything just for good measure and put a new head gasket on it. If your not able to do a professional job like this pay to have it done. Good luck and let us know
  10. Jul 29, 2014 at 8:16 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    This option is the best, cheapest and easiest one.
  11. Jul 30, 2014 at 12:49 PM
    chasdw
    chasdw [OP] Member
    Norman OK
    4WD
    Again, thanks for all the input.
    I dropped off my truck at the shop today. We will see what they have to say about the head gasket. (Block Test and leak down or compression test)
  12. Jul 30, 2014 at 1:12 PM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    I just went through your exact same issue last month. My Leak was SUPER small, and the only test that confirmed a bad gasket was an OVERNIGHT coolant pressure test. It's tough to decide what to do- get a new motor or rebuild yours. Heres what i figured when i did mine
    New engine- Minimum 2k plus mechanic cost to swap it, maybe another 1k.
    Rebuild your engine- $3050 from toyota (real quoted price), maybe less from a small shop. This doesnt include other random parts, so it will likely be alot more when all is said and done.
    Rebuild it yourself- about $1700 including head work and random parts youll want to replace
    You can do up to 2011 for sure, not positive about the newer ones but theyd probly work too. From what i know, 05-07 have the same issue with head gaskets, and it's unclear about 08- some say theyre updated and some say theyre not. if you get a new engine, be safe and get at least an 09.
    I ended up doing the head gasket on my engine rather than replacing, because i did it myself in my garage. roughly $1700 in parts and head work. The cool thing was that the engine still looks GREAT inside and i have 217k on mine. Be sure to check your exhaust manifolds while you have everything apart and make sure the cats arent blown out (mine were). I now have a great running engine about 1000 miles later no problems.
    It's def worth the fix on these trucks becuase i am confident i wont have any other major issues with the truck for a long time now, and shes in great shape. Plus they hold their value. Hope that helps
    PzTank likes this.
  13. Jul 30, 2014 at 1:24 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    LOLZ...........someones drinking the cool aid
    if Toyota quality is Sooooooooooooo great why have their trucks frames been recalled for the past 20 years?
    Ill never be blindly brand loyal like many here are. Toyota builds junk just like every other brand. Sometimes you get lucky and sometimes not.
    Oh and I got my new 'used' engine for $1,200.00.
  14. Jul 30, 2014 at 2:41 PM
    yota243
    E.J.
    north Alabama
    Toyota has to have some weak point, or no one would ever buy a new one, same reason ford stopped using the 7.3, they made sure to replace it with the 6.blow so there would repeat buyers every couple years. (Btw my alabama frame looks fantastic, other than being covered in red clay most of the time)
  15. Jul 30, 2014 at 2:43 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Time to go diesel. There is no other viable option. :rolleyes:
  16. Jul 30, 2014 at 2:45 PM
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    How are you spending 1700 on parts for a gasket replacement?
  17. Jul 30, 2014 at 9:32 PM
    ranger098
    Brian
    Minnesota
    Gasket kit, water pump, cam chain, head cleaning and testing, plugs and coils, 10 Qts synthetic oil and 2 filters, coolant, main engine belt, a few wheels on the engine that were seizing up, it adds up quick.
    I replaced some things I maybe didn't need to but I wanted it done right
    PzTank likes this.
  18. Jul 31, 2014 at 8:56 PM
    chasdw
    chasdw [OP] Member
    Norman OK
    4WD
    The shop is still trying to diagnose what I believe to be the head gasket failing.
    Block Test was inconclusive
    Overnight coolant pressure test did not leak down.
    Scope did not show any drops of coolant.
    Still waiting, man I miss driving my Tacoma...
  19. Jul 31, 2014 at 8:59 PM
    XXXX
    sKiP
    05 Prius
    Good luck man!
    Cylinder six is where my issues started. It's scorn and loses compression.
  20. Aug 4, 2014 at 12:19 PM
    ranger098
    Brian
    Minnesota
    Damn that sucks. try coolant testing the engine while hot... this might be the only time your issue rears its ugly head.
    Also you said that you swapped cyl. 4 and 6 coils, but i would try swapping coils off the other bank just to be safe. Other than that i'm stumped. maybe some kinda vacuum leak?
