1GR-FE oil passages
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Twizter68, Nov 3, 2018.
  1. Nov 3, 2018 at 1:34 AM
    Twizter68
    Twizter68 [OP] AMS1(AW), USN retired
    Bill
    Weatherford, TX and Fahad al-Ahmed, Kuwait
    08 Crew Cab Prerunner
    Anyone have a factory diagram of the oil passages on the 4.0l? I may have to pull heads and clean passages and returns out...one of those quick oil change places screwed my son while I was overseas.
  2. Nov 3, 2018 at 3:32 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    What exactly is the issue?
    scottalot likes this.
  3. Nov 3, 2018 at 4:17 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    :popcorn::popcorn:
  4. Nov 3, 2018 at 5:08 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    waiting for details.....................
  5. Nov 3, 2018 at 6:11 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Just run a high detergent oil to clean.
  6. Nov 3, 2018 at 6:38 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Hmmm.... trying to clean out bearing material perhaps?
  7. Jul 18, 2019 at 12:20 PM
    Twizter68
    Bill
    Sorry for the delay; was having codes pop for the #1 VVT solenoid, after I had replaced both and all the chains. Turns out the #1 unit I installed was poorly made, and wasn't porting oil properly. New one from Toyota fixed it.
    The reason for wanting the oil passage diagram was an unscrupulous "mechanic" was either putting recycled oil in, or only changing the filter when my son took it in for oil changes (I work overseas). Ended up sludging the motor BAD...enough that it broke the targets off the #1 cam phaser, and I was pulling ROCKS of carbonized sludge out of the timing cover and valvetrain. A lot of $$ in parts, a lot of sweat, and a bunch of mineral spirits and labor by me, and it's now running like a champ.
    lynyrd3 likes this.
  8. Jul 18, 2019 at 2:40 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Attaching a pdf that probably has what you are asking for around page 18.
  9. Jul 18, 2019 at 2:58 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Thanks for the file in a new member and the information I've been able to collect from other members has be excellent.
  10. Jul 18, 2019 at 3:01 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Use the cheap walmart synthetic oil and substitute one quart for ATF fluid. Should clean it right out.
  11. Jul 18, 2019 at 5:41 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Make sure you clean/replace those VVT screens too. Very fine mesh.
  12. Jul 18, 2019 at 5:47 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Atf works good or diesel in the crank case will help clean it out really well
  13. Jul 18, 2019 at 6:10 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Just curious, how long were you gone? Oil doesn’t just sludge up overnight.
  14. Jul 18, 2019 at 6:30 PM
    Taco'09
    Taco'09 Well-Known Member
