1GR-FE (Single VVTi) Dyno Testing by OTT
Discussion in 'Performance and Tuning' started by JustDSM, Mar 20, 2022.
  1. Mar 6, 2024 at 8:44 AM
    #101
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    I am curious about the effects of running a 170 degree thermostat.
  2. Mar 6, 2024 at 9:02 AM
    #102
    JustDSM
    JustDSM [OP] Oderint Dum Metuant
    Justin
    Ogden, UT
    On power? None.
    Hilborn[QUOTED] likes this.
  3. Mar 19, 2024 at 4:22 PM
    #103
    hilux30
    hilux30 Well-Known Member
    PEI
    '15 4Dr SB 6MT
    OTT tune 3 degree cam gear OME/Dobinson
    Just did this to my 1GR, love it! .. I can shift 1st to 2nd more efficiently and stay in power, the torque is noticeably fatter, the steep hills had to downshift to 5th, now 6th gear no problem (RC62 trans) .. worth every penny
    dave82at, Torspd and JustDSM[OP] like this.
  4. Apr 26, 2024 at 12:32 PM
    #104
    vettaco
    vettaco Well-Known Member
    Vince
    09 AC PreRunner
    Just did what to your 1GR?
    GilbertOz likes this.
  5. Apr 28, 2024 at 3:02 AM
    #105
    hilux30
    PEI
    '15 4Dr SB 6MT
    Got tuned...
  6. Jun 1, 2024 at 5:51 PM
    #106
    P4x4
    P4x4 Well-Known Member
    Pascal
    2015 Dark Gray Tacoma 4x4
    Thanks for this post and all your tests, sharing/analysis and data Justin! Very educational.
    So far for a Taco 2014, what is your takeaway (besides your comment about doing a proper and regular maintenance)?
    CAI? Spark plug? exhaust? etc...
    I will definitely consider a Tune but no OTT near by my place :/
    JustDSM[OP] likes this.
  7. Jun 2, 2024 at 11:12 AM
    #107
    JustDSM
    Justin
    Ogden, UT
    I still stand behind my statement that maintenance should be first and foremost before a tune. I say that even being in the business of selling calibrations. I'd prefer to tune 1 properly maintained vehicle than 2 poorly maintained ones. I'm less likely to have a customer with less than stellar performance due to the vehicle not working as intended, not to mention there will be far fewer issues I have to deal with from a customer thinking the tune will fix or mask the poor maintenance and issues associated with the lack of maintenance.
    I'd like to remind everyone here who may be following along. None of these modifications alone will turn this motor into a "monster". Each of these modifications is worth a few horsepower, and its the sum of these small improvements that will wake the truck up. If you go down the bolt on modification path thinking each one will knock your socks off, you will be disappointed. You see it all over the forum: "This mod doesn't do anything". Five-wheel horsepower on a 4600+lb vehicle isn't going to change the power-to-weight ratio enough to have a perceivable change in the rate of acceleration/put-you-in-the-seat performance.
    But some simple mods to improve the performance of the Single VVTi 1GR would be (in no particular order):
    1. Intake, something drawing air from outside the engine bay.
    2. 70mm OEM 5th Gen 4Runner Throttle Body (for N/A setups, or mild boosted applications)
    3. Intake Manifold Spacer (not a throttle body spacer)
    4. 3° Retarded Exhaust Cam Gears
    5. ECU Reflash/Tune
    6. Run "Premium" grade fuel.
    Exhaust is a tricky one. My testing shows the restriction is primarily the manifolds, then Y-pipe, with the cat-back being the least restrictive part of the exhaust for a N/A vehicle. The problem is there are legal implications with replacing the manifolds. The URD Spec-U headers are the best performing header I've tested but they remove the primary catalysts and I just cannot recommend doing that on a street vehicle. An alternative that might be worth looking into is the aFe Twisted Steel Header. I understand they had problems in the past with cats being blown out mostly on forced induction vehicles, but they've since upgraded their catalysts to high quality GESI cats.
    For the calibration, we offer remote calibration services where we can supply you all the hardware/software you need so you can tune it yourself in your driveway. If you aren't near one of our retailers we'd be happy to help you out. Send us an email to let us know how we can help. info@overlandtailor.com
    PNW15, jamesepoop, TireFire and 5 others like this.
  8. Jun 2, 2024 at 12:52 PM
    #108
    P4x4
    Pascal
    Thanks Justin.
    For the exhaust, there is also the "comfort" if the truck is a daily drive.
    I will keep the email and probably ping you back in September.
  9. Jun 29, 2024 at 2:52 AM
    #109
    mutazs
    mutazs New Member
    Hi
    Is there dyno test result for the 3 degree cam retard ?
    thanks
    herecomesace likes this.
  10. Jun 29, 2024 at 6:47 AM
    #110
    JustDSM
    Justin
    Ogden, UT
    We have them in inventory, and in the que to test. But at this time we do not have results for them.
  11. Aug 20, 2024 at 9:43 PM
    #111
    Tootall604
    Tootall604 Well-Known Member
    2015 Tacoma sb
    Following.
  12. Sep 24, 2024 at 7:34 AM
    #112
    hmgtaco09
    hmgtaco09 hmgtaco19
    2019 Tacoma TRD off-road dlbcab
    Bilstein 5100, OME 887 Coils second notch, SPC UCA, Deaver 1.5-2 AAL
    I would love to see a dyno for 3rd gen V6 with aes spacer plus the tune.
  13. Sep 24, 2024 at 7:57 AM
    #113
    JustDSM
    Justin
    Ogden, UT
    Send AES and email and tell them you'd like to see OTT test their spacer - OTT will make it happen.
    hmgtaco09[QUOTED] and Torspd like this.
  14. Nov 6, 2024 at 7:24 PM
    #114
    Answ3r
    Answ3r Member
    Is it me or the cam gears are useless if you have a tune ? You could dial exactly the 3 degres offset they offer anywhere in the tune, no ?
  15. Nov 6, 2024 at 7:53 PM
    #115
    PNW15
    PNW15 Well-Known Member
    2015 Tacoma DC LB SR5
    Nope, the exhaust side of the head does not have variable valve timing only intake. At least on the Tacomas. Some 4runners have dual VVTI and I don't think anyone cam gears those.
    Therefore, cam gears are the only way to retard exhaust timing on a Tacoma 1GRFE
  16. Nov 7, 2024 at 5:47 AM
    #116
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Definitely not useless if you do not have a tune. I ran mine for almost a year before I got a tune.
    Well worth the effort.
