1GR-FE Tune-up Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DesertRatliff, Jul 23, 2015.
  1. Jul 23, 2015 at 7:33 AM
    DesertRatliff
    DesertRatliff [OP] Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Hi all,
    I know my 2000 Tacoma like the back of my hand, but am just getting to know my wife's 2006 1GR-FE 4x4. She got it a year and a half ago and it now has around 127K on it. We got it about as cheap as you can find a 2nd gen Double Cab, but I knew going into it all that it would need some work as the PO family was hard on it and had no maintenance history.
    So far, I've replaced:
    -carrier bearing and u-joints (one u-joint found a way to replace the needle bearings with red dust. Cool trick!)
    -front wheel bearings with nj636's kit.
    -F/R brake pads w/ slotted front rotors
    -oil and oil/air/cabin filters (a few times now)
    -gear boxes flushed
    It's time for the motor to get some love. I'm thinking:
    -water pump (losing coolant from somewhere) w/ coolant flush
    -spark plugs
    -fuel filter
    -accessory belts
    Am I missing anything while I'm in there? Thanks!
    nj636 likes this.
  2. Jul 23, 2015 at 7:40 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Yeah that ^^
    Fuel filter is in the tank and I hear you have to replace the whole sending unit to actually replace it. So good luck with that. There are aftermarket options to get separate sending unit and filters.
    And that VV
  3. Jul 23, 2015 at 7:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Do the fuel pump upgrade kit from URD. www.urdusa.com. It makes the fuel system where the filter can be replaced easily and it is an external filter. Only about $150. Much cheaper than the OEM replacement of about $500.
  4. Jul 24, 2015 at 5:30 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Cool. Thanks guys.
