1grfe Exedy or CC-3 Clutch.
Discussion in 'Performance and Tuning' started by Boost JuNkY, Jan 22, 2012.
  1. Jan 22, 2012 at 6:42 PM
    Boost JuNkY
    Boost JuNkY [OP] Well-Known Member
    Billy
    Vancouver, BC
    2006 DC SPORT 6MT
    885's, OME Nitros, AP 3" leafs, DTLT's, Magnaflow Exhaust, TRD SS, AFE prodry S, URD Maf Cal, Exedy Clutch, URD TOB, Bhlm, AP winch bumper, Daystar 9" lights, OEM roof rack, Yakima fairing, Bed & rock lights, Sony Sub & Amp, 48" Hi Lift, 4X sliders,
    Anyone running this clutch in their trucks? I wanted to know how you like it compared to oem. Exedy rep told me it had a lighter pressure plate and made me concerned about slippage in 4x4.
    CC seemed to be good but its more money.
    Im also gonna run it with TOB sleeve kit.
  2. Jan 23, 2012 at 5:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Lighter pressure plate just means a gains of whp due to a loss of rotating mass. Clamping pressure is what will keep you from slipping. I would ask exedy if their clamp pressure is more than OEM or the same. I know two things about them. They make some of the best aftermarket clutches for performance vehicles, and they won't make a clutch with less than OEM clamping pressure.
  3. Jan 23, 2012 at 4:06 PM
    Boost JuNkY
    Billy
    Vancouver, BC
    2006 DC SPORT 6MT
    Sorry, what I meant was lighter clutch pedal feel, not the actual PP weight. I was told its the same torque cap as OEM toyota.
  4. Jan 23, 2012 at 4:18 PM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    I have the CC Stage 3 Clutch in my truck and i love it, holds excellent. Requires a ggod amount of break in time. I got a really good deal on it that i couldnt pass up, otherwise i would have gone with something less aggressive, given my engine is stock. The clutch pedal is definitely lighter than stock, but that could have some thing to do with me removing the clutch fluid accumulator.
  5. Jan 23, 2012 at 9:03 PM
    Boost JuNkY
    Billy
    Vancouver, BC
    2006 DC SPORT 6MT
    Thanks for the reply! Do u find the stage 3 chattery at times or does it just grab harder but drives stock-like ?
  6. Jan 23, 2012 at 10:25 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    It just grabs a lot harder, but drives like stock
  7. Jan 25, 2012 at 8:19 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    Here is another option.
    http://www.nonstoptuning.com/SPEC/pSpecClutch.html
    Higher on the quality scale, but price reflects that as well. I run the Stage 3+. Quite a bit more than necessary for most. I have installed the Stage 2+. I recommend that for most people. OEM smooth engagement on first test drive.
  8. Jan 25, 2012 at 8:48 PM
    Boost JuNkY
    Billy
    Vancouver, BC
    2006 DC SPORT 6MT
    Thanks for the response guys! Much appreciated.
