1grfe pricing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dipstiktaco, Jan 28, 2017.
  1. Jan 28, 2017 at 7:49 AM
    dipstiktaco
    dipstiktaco [OP] Well-Known Member
    canada
    2006 TRD off road access cab auto URD supercharged
    So I snapped a rod on the new used engine I put in my supercharged tacoma. That engine cost me 2900$cdn. Now I'm looking for another on and the prices are all around 4k used. Why are these engines so expensive?! The 2uzfe v8 is less than a third the price for similar mileage and condition and it has two more cylinders! Is it possible to put the 2uz into a tacoma if you use the 4runner wiring, mounts, ecu, and bellhousing? All the associated parts to do the swap might end up being cheaper than getting another 1gr and you get a v8. Yes I know they both have their downfalls, 2uz is iron with weak rods and the 1gr at least in my experience hates higher boost. Let's hear some opinions
  2. Jan 28, 2017 at 7:52 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    2 different engines? You're doing something wrong.
  3. Jan 28, 2017 at 8:01 AM
    dipstiktaco
    canada
    One melted the pistons due to bad fuel and the other snapped the rod at 2000rpm without the supercharger hooked up so it was shit luck
  4. Jan 28, 2017 at 8:27 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    what kind of oil are you running? that's is some really bad luck to go through 2 engines like that.
  5. Jan 28, 2017 at 9:12 AM
    dipstiktaco
    canada
    Castrol syntec 5w30
  6. Jan 28, 2017 at 9:22 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    have you run any oil test at all? these engines are tougher then a brick wall. I tried to destroy mine before 30k miles but it just took everything I threw at it. something is off to me here though. how did you have you SC unhooked? that's what forces air into the combustion chamber to alow it to fire. sounds almost like timing to off for fuel to detonate a piston like that. but what happened, happened time for a V8 swap.
  7. Jan 28, 2017 at 9:41 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    What is "higher boost"?
  8. Jan 28, 2017 at 2:23 PM
    dipstiktaco
    canada
    Urd stage 3. The intercooler charge piping wasn't attached and it had the stock tune and injectors in it. Superchargers do put air in the cylinders but it will run without it.
  9. Jan 28, 2017 at 2:29 PM
    Large
    Large Red
    why not change the rod unless you did something catastrophic, or have a motor built since it will be your 3rd one and you like boost
  10. Jan 28, 2017 at 2:49 PM
    dipstiktaco
    canada
    Hole in the block. I'd still need another engine to build as my other one has damaged bores. I'm most likely going to sell the supercharger hence the v8 swap it's to keep some of the power. Yes I know it's not much more but it's easier to make more out of the 8 than the 6
    inwood customs likes this.
  11. Jan 28, 2017 at 3:04 PM
    inwood customs
    Dave
    @nfs257
    nfs257 likes this.
