1GRFE rebuild issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by randy59, Aug 22, 2023.
  1. Aug 22, 2023 at 2:05 PM
    randy59
    randy59 [OP] New Member
    Randy
    off road suspension and winch
    I am having a great deal of trouble sourcing connecting rods for a 1GRFE, 4L motor out of a 2012 Tacoma, Toyota says that the existing rids should have a letter A,B,or C stamped on them mine have W1 stamped on them, any assistance on this issue would be greatly appreciated
  2. Aug 22, 2023 at 2:23 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
  3. Aug 22, 2023 at 2:25 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  4. Aug 22, 2023 at 2:38 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Torspd and BassAckwards[QUOTED] like this.
  5. Aug 22, 2023 at 2:40 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
  6. Aug 22, 2023 at 2:43 PM
    TnShooter
    Deogee
    STOCK
    The W1 is the front mark.
    It indicates what way the rod and piston mark goes on when assembled.
    The only reference to A,B,C are for the bushings.
    But I only read over the inspection data briefly.
    Torspd will likely know.
    Torspd likes this.
  7. Aug 22, 2023 at 2:44 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome To TW..
  8. Aug 22, 2023 at 3:55 PM
    BassAckwards
    Good to know there are some other options out there for cheaper. I got the LCE rods for my 2TR and they were made by Pauter. I remember mine being painfully expensive as well.
    TnShooter[QUOTED] and Torspd like this.
  9. Aug 22, 2023 at 3:57 PM
    randy59
    Randy
    Thanks guys much appreciated
  10. Aug 22, 2023 at 4:10 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :anonymous:
  11. Aug 22, 2023 at 4:12 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    BassAckwards[QUOTED] likes this.
  12. Aug 22, 2023 at 4:23 PM
    BassAckwards
    I was wondering what you were running. Ouch, that is expensive for sure. Not something you want to give up on you though, so worth the money in your case
  13. Aug 22, 2023 at 5:45 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The Pauter rods were designed off of the #2 stamped OEM rod. Waaaaay back when. I think the Molnar rods were as well. I sent both companies a rod each. Regardless, bearing to crank journal clearances must still be checked.
    The Brian Crower rods are offered with two choices of rod bolt fasteners. Strong, and super strong.
    Not sure if Pauter, or Molnar offer the Aged 625 series fasteners.
    BassAckwards likes this.
