1inch spacer + 3 in lift from fox CO's???
Discussion in '1st Gen. Tacomas (1995-2004)' started by FBGW01, May 17, 2012.
  1. May 17, 2012 at 11:02 PM
    FBGW01
    FBGW01 [OP] Well-Known Member
    Kaleb
    East Mesa AZ
    check my build
    Alright so i got the rear end suspension pretty much finished up. it sits a bit stink bug(rear end high) and i want to have a some bro lean. the back is quite a bit higher saying i have all pro leaf pack (3in lift) and fox 2.0 resis. so in order to get the front higher then the back without getting LT or 6in lift, can i get the Fox CO resi's (cranked to 3in lift) and put a 1in top spacer on those?:confused: Im just curious to see if this will work. im 2wd so no CV angles to worry about. and i am puttin on 1in uniball upper control arms. just dont know if the spacer will lift it an extra in so im +4" lift in the front?
  2. May 17, 2012 at 11:10 PM
    FBGW01
    Kaleb
    East Mesa AZ
    check my build
    alright. well hopeully the leafs settle more because there still really new. also took 2 leafs out per side. so ill run the CO's up front at 3in lift and see if that levels it out and over time back wears in good to be tad bit lower:)
    Spindles for my truck, since its a first gen, are like 1500! i plan on just gusseting those up later
  3. May 17, 2012 at 11:16 PM
    FBGW01
    Kaleb
    East Mesa AZ
    check my build
    haha ya i got the sand in there the first two weeks. killed milage. still have 16 salt pellet bags i was using and it was about 800lbs of stuff:eek: haha settled it a little and looked like a nicee bro lean hahaha. but took it out for now. save me money on gas.
  4. May 18, 2012 at 6:32 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Never stack lifts
  5. May 18, 2012 at 6:57 AM
    02TACOMA4WD
    02TACOMA4WD Well-Known Member
    02 Tacoma TRD 4x4
    What coilovers are you running upfront?
  6. May 18, 2012 at 7:04 AM
    FBGW01
    Kaleb
    East Mesa AZ
    check my build
    putting fox CO's (coilovers) up front. resi's:cool:
