1K mile oil change or not
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4runnerToTacoma, Aug 26, 2023.
  1. Aug 27, 2023 at 7:58 AM
    #81
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    Rings and bearings are seated at the factory. This is not a process that falls on the end user. If you buy a crate motor or rebuild an engine this is something that needs to be done. The main purpose of changing the engine oil early is to reduce the amount of metal in the oil. I honestly don’t understand why people debate this when universally UOA’s show very high levels of iron in particular, aluminum, and copper. Even Amsoil own website specifically states their break-in oil is only for these types of engines. Not needed for a factory engine that has already been seated. It’s also states this should be done at 200 miles. 90% of engine break-in is finished by 500 miles. Waiting until 1k is not doing yourself any favors.
    I personally change the oil, or extract the oil, multiple times to help reduce this level of iron, copper, and aluminum to a minimum. The idea is to prevent microscopic scoring or at least minimize and I also start using Liqui Moly’s Cer Tec at 1k miles. The idle smoothness is substantially better after treatment.
    This is about 300 miles after cera tec treatment. The idle is so smooth now I can barely tell the engine is running. Look at rpm’s and how they vary minimally.
    https://youtube.com/shorts/IAOz2GEPL-Y?feature=shared
    abqjoe and Merling like this.
  2. Aug 27, 2023 at 8:12 AM
    #82
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    I agree but engine smoothness has basically no correlation with wear performance.
    SmoothTRD likes this.
  3. Aug 27, 2023 at 8:40 AM
    #83
    lavrishevo
    2023 Trail Edition
    yes, the Cera Tec does improve this tremendously.
  4. Aug 27, 2023 at 9:25 AM
    #84
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Like most here if you want change it. I like the 5k number or 12 months for those who don’t drive many miles
    zoo truck likes this.
  5. Aug 27, 2023 at 9:25 AM
    #85
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I'd need to see proof on that as far as rings, and bearings being seated at the factory. I've never heard of this for our mass production engines, only that they might test one out of a batch for qc. You're not dealing with some of these hand build engines where they are dyno tested before shipped. It's up to us to follow the manufactures engine recommendations when breaking in a new vehicle.
  6. Aug 27, 2023 at 9:40 AM
    #86
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    Yes. Also, when I use ketchup, I open and close the bottle 4 times to make sure I remove all of the air and that it is pristine for my next use. Nothing else will suffice. This isn't a form of obsessive compulsive disorder, it's proven (in my anecdotal studies) to improve ketchup performance.
  7. Aug 27, 2023 at 11:25 AM
    #87
    Sandthemall
    Sandthemall Well-Known Member
    Sandamal
    2023 TRD OR MT
    Exactly my point: it's dirtier...lol. It's 5k miles dirtier...and diluted with fuel among other things.
    I think your point may be that, in reality, it's only marginally dirtier...but some of us believe that year upon year, mile upon mile...it will reach a tipping point. And no amount of preventative maintenance is gonna get back what you lost.
    zoo truck[QUOTED] likes this.
  8. Aug 27, 2023 at 11:28 AM
    #88
    cowfootball
    2022 TRD OR
    Why stop at 1,000 miles then? Why not change your oil every 100? Every mile makes a difference!
    Xx_Evilvirus_xX likes this.
  9. Aug 27, 2023 at 11:29 AM
    #89
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    If you put in 93.27 octane it runs like a bat out of hell. Also I change the oil on days ending in Y.
    abqjoe likes this.
  10. Aug 27, 2023 at 12:00 PM
    #90
    zoo truck
    None
    Don't you think thats way too late? Oil sure has some strange effects of different owners.
    islandhiker[QUOTED] likes this.
  11. Aug 27, 2023 at 1:18 PM
    #91
    lavrishevo
    2023 Trail Edition
    Check the link. Believe me, 99% of consumers have no idea how to seat rings and bearings. Putting this on the average consumer would be disastrous.
    “When breaking in an engine, it is important to vary the load on the engine. A dynamometer often has a preset break-in mode that varies load and engine RPM.”
    https://www.enginebuildermag.com/2018/05/how-to-break-in-your-piston-rings-the-right-way/
  12. Aug 27, 2023 at 4:30 PM
    #92
    North7
    North7 Well-Known Member
    2022 trdor
    Fuel smell at first oil change is usually due to rings not yet seated. 1000 mile oil change may be premature. But if it let's you sleep at night, go 4 it.
  13. Aug 27, 2023 at 4:33 PM
    #93
    rtilton12
    rtilton12 Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    i do mine every 4-5k miles with castrol or mobil 1 and add marvel mystery oil in the mix. 130k miles and purrs like a kitten. its all shiny when you look into the filler neck (where you add your oil)
    to each their own
    oneikr and TheFactor like this.
  14. Aug 27, 2023 at 4:49 PM
    #94
    TheFactor
    TheFactor Well-Known Member
    So Cal
    2023 Tacoma TRD Off road
    When I bought my Taco I also purchased wheel locks and when it was in for service because they weren’t rotating the tires they wanted charge me more then the wheel locks to put them like 75 bucks and I said no thank you very much.
  15. Aug 27, 2023 at 5:07 PM
    #95
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    huh?
  16. Aug 27, 2023 at 5:10 PM
    #96
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Yep…..sounds about right
  17. Aug 27, 2023 at 5:50 PM
    #97
    zoo truck
    None
    Yes I know enough about various class engine builds to be dangerous from hanging out at a friends nascar engine facility. They use special break-in oil on all newly built engines, then run them on a dyno before shipping them out. I've never heard of any manufacture doing this for their mass produced engines. I've seen how various type synthetics make it very hard for rings to seat, or not seat at all, opposed to using a dino break-in oil, it happens fairly quick as long as good cylinder pressure is made during several pulls.
  18. Aug 27, 2023 at 6:01 PM
    #98
    TheFactor
    So Cal
    Yes exactly what I said when they told me the price to install them .
    Dark_Taco likes this.
  19. Aug 27, 2023 at 6:16 PM
    #99
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    No normal automotive manufacturer does that. They don’t send the vehicle out with any special oil.
    Toyota guidelines call the Tacoma “broken in “ at I believe 620 miles. No special oil is used, it only makes sense to get the heavy metals out of the oil as soon as possible. And while the filter does catch some stuff, it doesn’t remove everything. And engine braking in causes particles smaller than the filter will catch.
  20. Aug 27, 2023 at 6:20 PM
    #100
    Forestexplorer
    Forestexplorer Well-Known Member
    Forest
    Napa Ca
    2019 Tacoma TRD Offroad
    I’ve never heard about changing it after 1k thanks for the info
