1K mile oil change or not
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4runnerToTacoma, Aug 26, 2023.
  1. Aug 27, 2023 at 6:22 PM
    #101
    SmoothTRD
    SmoothTRD Well-Known Member
    Lol still doing my 10k changes with whatever I find on sale, my baby will go 500k
  2. Aug 27, 2023 at 6:25 PM
    #102
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    You have now….
  3. Aug 27, 2023 at 6:30 PM
    #103
    Forestexplorer
    Forestexplorer Well-Known Member
    Forest
    Napa Ca
    2019 Tacoma TRD Offroad
    deflowered
    clownkillerloaf and Tundy like this.
  4. Aug 27, 2023 at 6:31 PM
    #104
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
  5. Aug 27, 2023 at 6:34 PM
    #105
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    This is done when the engine is assembled at the assembly plant. Think about it logically for a min and how the procedure is done. The seating of the rings and bearings is very specific. It’s not reliant on some dude take the car or truck around a track for a few miles if that. It is done on a specialized machine. They don’t just plop the engine in a body and hope for the best. This would be illogical. Most engines are hand built for the most part.
    If this was not the case why would Amsoil say break-in oil is not needed for new engines from the factory? It only applies to crate and rebuilt engines. I’ve seated rings before on a rebuilt motor and it was for the most part with the car in park before it is driven hard. The break-in manufacturers reference is not the seating of the rings and bearings. This is not what they are referencing nor are we specifically talking about in this thread, or at least so I thought… I’m telling you, our engines would be f’d up if this was not done at the factory.
  6. Aug 27, 2023 at 6:37 PM
    #106
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    :D
  7. Aug 27, 2023 at 6:39 PM
    #107
    lavrishevo
    2023 Trail Edition
    Amsoil specifically mentions 200 miles. If you think about it logically it makes sense why.
  8. Aug 27, 2023 at 6:41 PM
    #108
    lavrishevo
    2023 Trail Edition
    You are missing the point…
  9. Aug 27, 2023 at 7:09 PM
    #109
    lavrishevo
    2023 Trail Edition
    zoo truck likes this.
  10. Aug 27, 2023 at 7:21 PM
    #110
    lavrishevo
    2023 Trail Edition
    When do I use break-in oil?
    New cars and trucks don’t need break-in oil. The manufacturer will typically require you to drive under light-to-moderate load for a few hundred miles, then change oil. After that, you’re good to go.
    Racers, competitors or gearheads using a rebuilt or new crate engine, however, should use break-in oil. Follow the engine builder’s directions or the instructions that came with the crate engine.
    How long to run break-in oil?
    Another rule of thumb states you should season a flat-tappet cam by running the engine above 2,500 rpm for 15 minutes.
    As for seating the rings, our testing has shown it can take as few as seven dyno passes. That time varies depending on the engine, ring tension, cylinder hone and other factors.
    Engine builder Jesse Prather used to run an engine 2-3 hours on the dyno to seat the rings…if they seated at all. Using AMSOIL Break-In Oil reduced that time to just 10-15 minutes.
    https://blog.amsoil.com/why-you-sho...ng-break-in-oil-in-powersports-equipment/amp/
  11. Aug 27, 2023 at 7:48 PM
    #111
    Forestexplorer
    Forest
    Napa Ca
    Thanks!
  12. Aug 28, 2023 at 4:45 AM
    #112
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    The issues with manufactures, they want to eliminate as many warranty claims as possible telling owners to baby their vehicles during the break-in period. The end result is usually less engine hp numbers for the life they own their vehicle. It doesn't hurt a new engine to put the heel to the steel for short periods. Just refrain from constant driving like you stole it.
  13. Aug 28, 2023 at 3:15 PM
    #113
    abqjoe
    abqjoe Member
    2023 Tacoma TRD & 07 Toyota FJ Cruiser
    You mean like 1100 miles worth of driving?
  14. Aug 28, 2023 at 6:03 PM
    #114
    zoo truck
    None
    Not sure what's meant by that comment, but I didn't exactly baby my truck for the 1st 1200 miles. I think doing some moderate towing at 500 miles helped, plus the need to blow by a few slow poke's.
  15. Aug 29, 2023 at 4:17 AM
    #115
    Ed_Force_1
    Ed_Force_1 Up the Irons!
    Jeff
    Battle Creek, MI
    2023 Limited Nightshade
    Interior LED lights, hood struts, Weather Tech floor mats, Toyota bed mat, screen protectors, sill protectors, Pop & Lock power tailgate lock, McGard tailgate anti-theft lock, gas cap holder, iArmor drop step running boards.
    I changed my oil at 1000 miles, then 5000, and will change at 5000 mile intervals until I sell it.
  16. Aug 29, 2023 at 4:49 AM
    #116
    zoo truck
    None
    I keep feeling were back in the 70's, and 80's when dino oil was king.
    SmoothTRD likes this.
  17. Aug 29, 2023 at 6:23 AM
    #117
    4runnerToTacoma
    4runnerToTacoma [OP] Well-Known Member
    22 SR5 V6 Taco, 03 SR5 V6 4runner
  18. Aug 29, 2023 at 6:42 AM
    #118
    xp0nex
    xp0nex Taco Noob
    2022 MGM TRD Off-Road DCSB 4x4
    I did mine at 200 then my second at 1200. I am currently at 2100 and reaching its 1 year anniversary. I rarely drive due to WFH so moving forward I will change it either every 6 months or 5K miles whichever comes first.
    Ed_Force_1 likes this.
  19. Aug 29, 2023 at 7:23 AM
    #119
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    6 months is overkill. You can go at least a year.
  20. Aug 29, 2023 at 7:29 AM
    #120
    Ed_Force_1
    Jeff
    Battle Creek, MI
    I belong to the 6 months or 5000 miles school.
    But you can change it more often or less so as you see fit.
